engine swap help.
Old Apr 9, 2009 | 09:26 PM
  #91
symonds86's Avatar
symonds86
sweet except for the dmv, i hate that place
Old Apr 9, 2009 | 09:28 PM
  #92
George D.'s Avatar
George D.
At least you get to take a number and sit while you wait ath the DMV here.
Old Apr 9, 2009 | 09:31 PM
  #93
joe f350's Avatar
joe f350
how close are u to beening done
Old Apr 9, 2009 | 09:32 PM
  #94
George D.'s Avatar
George D.
rad, fan, shroud, air cleaner and CDR. And I may have to turn down my timming a bit I had a pretty hot tune on the 7.3 but I have to get the rad in so i can runn it and get the air out and see how it runs.
Old Apr 9, 2009 | 09:41 PM
  #95
joe f350's Avatar
joe f350
get it done soon i glad u got to keep ur truck and beat ur room mate chevys in to the ground
Old Apr 9, 2009 | 11:38 PM
  #96
Dave Sponaugle's Avatar
Dave Sponaugle
That pintle hook is just bolted to the reciever tube reinforcement?
Yeah, I am surprised it didn't just pop right off.
You must have better horseshoes than I have.
You can tell the guys you work with I am running 25 pounds of boost on my 6.9.
Over 40K miles on the rebuild now.
Old Apr 9, 2009 | 11:45 PM
  #97
George D.'s Avatar
George D.
Yup thats how its mounted and no i don't tow with it. We PDIed some trucks that came with them and the customer wanted them remove so I have 3 more in my tool box. I just put it there to protect the bumper. When i get the money I will buy a the reciver mount for it. I took the sling out there expecting to hook on to the safty chanin holes but the hooks on the cains were too small so I figured I would give this a shot.
I think it was the one time my horse shoes were working.
Oh And they were saying it wouldn't hold the boost because of the compression ratio so they wouldn't cout yours. Some of them are already making bets as to how long befor i blow this one up. I don't remeber blowing the second one up although several people insist it blew up because I "recycled my used oil" wich cause my EGTs to go up and say if I do it again it will melt this one too.
Old Apr 10, 2009 | 12:33 AM
  #98
David85's Avatar
David85
LOL, EGTs and cavitation. Haven't heard of that link before.
Old Apr 10, 2009 | 12:45 AM
  #99
George D.'s Avatar
George D.
Thats what I said. Yeha I've had several people come up and ask me if it was true that i blew it up running used motor oil I said no. One guy swears if it hadn't gone from cavitation I would have melted it. Funny since the less than 3 gallons of motor oil it held mixed with the 20 or more of diesel I forget what my big tank hods made no difference on my pyro wich every one assumes I dont have and I'm just slaping stuff together and running a turbo on a motor never intended for one with no way of monitoring boost and EGT. When will people relise I'm not as stupid as they look.
Old Apr 10, 2009 | 12:47 AM
  #100
Dean88's Avatar
Dean88
Heck, I ran about a mixture of 50% new cotton seed oil and diesel last summer without any problemos, a little oil never hurt anything
Old Apr 10, 2009 | 01:00 AM
  #101
David85's Avatar
David85
These things will burn almost any oil that will still flow through a pipe. Guys on OBN have racked up 1000s of miles on strait motor oil. I can't say I've had any problems with ULSD even though I never run additive, but having a little oil in the system does more good than harm.
Just watch the EGTs and make sure the filter(s) don't clog up.
Old Apr 10, 2009 | 06:46 PM
  #102
George D.'s Avatar
George D.
Darn radiator shop said they would come get it this morning and have it back by the end of the day but they didn't get it till 1:30
Old Apr 10, 2009 | 11:16 PM
  #103
dyoung14's Avatar
dyoung14
george if they think yours is going to blow up because it has a factory turbo on it, tel them what kinda turbo im putting on my idi, thats sure to drive them crazy
Old Apr 10, 2009 | 11:25 PM
  #104
George D.'s Avatar
George D.
Asuming you can spool it, actual you may be able to since its the waste gated one if i were you i would lengthen the waste gate actuator as much as you can with it still holding the gate closed testdrive and re adjust thats what I'm going to do with my 6.9 sine i don't know where the stock setting is any more.
I ran it a bit more and i'm definatly going to hae to take some timing out of it.
Old Apr 11, 2009 | 01:34 PM
  #105
dyoung14's Avatar
dyoung14
i already adjusted the rod most of the way out, as i dont realy want to have to adjust it with the turbo in the truck, cause it is very tight in there.
