Steering problem (wheel jerks back and forth)
Old May 31, 2009 | 09:11 PM
  #166
EXv10's Avatar
EXv10
Itis been 2 weeks now with no problems. I think the new PS pump helped the ailing PS box enough to fix the problem. It acted up 1 time the day I put the pump in and that was the last time. Maybe air in there still. I will post back in a week.
Old May 31, 2009 | 10:53 PM
  #167
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
I hope you fixed it,it's been long and must be frustrating.
But you guys help all of us .Thanks
Old Jun 3, 2009 | 05:48 AM
  #168
73mach11's Avatar
73mach11
i had the same problem with my 01 with the 5.4L 108k miles.
i changed the power steering pump last year and its been fine. at first i thought it was the 4x4 axles somehow being engaged so i pull the guts out of the hubs and put the hubs back in. still had the problem. i was just shooting the breeze with a ford guy and i told him what i was dealing with. he said just change the pump. i did and all has been well. i did this back in sept 08.
Old Jun 3, 2009 | 10:06 AM
  #169
EXv10's Avatar
EXv10
The pump did it for me too. It's been 3 weeks now and it has never gone that long without acting up. I thought it might be my right hub also because of the wiggly action the u-joints can give but I ran it without hubs a no changes. I think the PS box does it but it is because it doesn't have enough pressure to it.
Old Jun 3, 2009 | 09:32 PM
  #170
Pinky Demon's Avatar
Pinky Demon
I did the pump, but that didn't solve it. I'm thinking if it keeps giving me crap, it'll be on to the steering gearbox next. Urrgh.
Old Jun 3, 2009 | 09:42 PM
  #171
EXv10's Avatar
EXv10
Bummer. I think my pump barely solved it because it did it again the same day I replaced it so I might have to do the box one of this days too............good luck.
Old Jun 6, 2009 | 02:20 PM
  #172
disturban's Avatar
disturban
I changed my box on my Suburban and have not had a problem since my last post...remember I also changed the pump and thought I solved the issue but it came back. I think it is a sticky valve in the box that causes this and after I changed the pump the new fluid helped for a little while. Knock on wood with the new box no problems so far...I reused the fluid this time so that will not be a contributing factor.
Old Jun 6, 2009 | 07:55 PM
  #173
EXv10's Avatar
EXv10
Mine is still good after changing the pump .................so far.
Old Jun 14, 2009 | 10:21 PM
  #174
X Club's Avatar
X Club
My '01 Excursion with the Powerstroke diesel has been doing the same thing, worse when towing. Did you replace the PS pump with a factory unit or aftermarket? I recently purchased the vehicle and it had oversized tires/lift etc, so I am thinking that the pump was overworked. Thoughts?
Old Jun 15, 2009 | 12:46 AM
  #175
EXv10's Avatar
EXv10
Probably overworked. Aftermarket. Does the pump make a sshhh noise when you turn? Can it turn the wheels lock to lock stopped with your foot off the brake? I think those pumps are different on the diesel?????
Old Jun 15, 2009 | 03:39 PM
  #176
X Club's Avatar
X Club
The pump has a bit of a whine to it all of the time. With the bigger tires on I could not turn the wheels much at all, but with the smaller tires I can turn, but it is still harder than it should be. I talked with my local Ford service dept and they suggested the front U-joints as well, but based on what I have read the PS pump is an easier place to start.
Old Jun 15, 2009 | 07:51 PM
  #177
EXv10's Avatar
EXv10
I wouldn't change the U-joints. They get little use and are only subjected to 1/3rd of the pulling force each when they do. I wish I had all the money people wasted on front u-joints. The PS pump should easily turn your wheels lock to lock on dry pavement with foot off the brake. I believe larger than stock tires also. I made the mistake of getting the pump with no pulley. Maybe that's the way they all come.
Old Jun 15, 2009 | 07:59 PM
  #178
X Club's Avatar
X Club
Me too, how hard was it to pull the old pulley off? I am just starting the project and have the PS Pump out on the bench. I will let you know how it goes.
Old Jun 15, 2009 | 08:25 PM
  #179
EXv10's Avatar
EXv10
You need a press. I had to walk a mile to a garage with it in a back pack and they did it on the spot. They wanted to charge 1/2 hr time but I squacked and they ended up charging $25.
Old Jun 15, 2009 | 09:46 PM
  #180
Pinky Demon
Haven't had any problems for a while, however, the truck did sit around for a week or 2 to get new U-Joints on the driveshaft, and since, I have not had any problems, knock on wood.
