Steering problem (wheel jerks back and forth)
Old Mar 1, 2019 | 05:08 PM
  #316
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by theonlypheonix
just an update date on my past problem, 10,000 mi down the road and all is good after replacing front right axle U-joint(seized) and right front wheel bearing(very noisey). Warn hub was in good shape and clean, just added a little more fresh grease. As a matter of PM I replaced ALL seals. Its worthy to note that the front diff tube dust seals have been redesigned because the original wear out quickly (both of mine were totally gone). I guess this means that this summer I'm tearing into the left side. Also highly recommend Spicer U-joints over joints like Precision (just don't seem to have the same level of quality as a Spicer but the Precision are CHEAP).
Originally Posted by Bohunter!
mine is a 2011 and having same issue did you ever figure out what it was?
post # 218
Old Mar 1, 2019 | 05:37 PM
  #317
erniek70's Avatar
erniek70
New U joints fixed mine no problem
Old Mar 8, 2019 | 07:43 PM
  #318
Nowrenchnick's Avatar
Nowrenchnick
Jerk!!!
I just installed new u joints in front axle shafts last night and it fixed mine!
Old Mar 20, 2019 | 05:56 PM
  #319
kxp7000's Avatar
kxp7000
okey, Im reed all 22 Pages and Im going to start my fight with flying on the road. I will let you now what it was if its help. 😓
Old Mar 21, 2019 | 12:21 AM
  #320
theonlypheonix's Avatar
theonlypheonix
Check your u-joints, 8 years and 60K miles later this problem has not resurfaced after I replaced the right front 1/2 shaft u-joint which was seized up
Old Apr 1, 2019 | 08:56 PM
  #321
Timberframer03's Avatar
Timberframer03
I joints
Man, you guys are a wealth of knowledge. I was experiencing the crazy steering wheel jerking and this thread turned me on to the u joints...seized. Replaced. Fixed. Thank you all for the help. Joining this forum keeps being the best thing I've done since buying my excursion.
Old May 11, 2019 | 06:53 AM
  #322
jdw1's Avatar
jdw1
Thanks for everyone’s input, at 316’xxx miles my 2000 Ex just started this steering issue as well.
Now I know what I’ll be doing next weekend!
where is everyone getting the new u-joints from?
Old May 11, 2019 | 05:14 PM
  #323
NJeXrow's Avatar
NJeXrow
I just had to do this. U Joint was so frozen that I had to cut it out. Nearly bent my outer stub shaft. Did everything on the left side this time I’d take care of ball joints when you have it torn down that much already unless those are new. You usually need to change the hub seal every time you pull the axle those seals add up.
Went with spicer u joints from Amazon. Called around to some local parts stores and they wanted ~70 for one u joint.
Amazon was under 50. If you have Prime, only thing that occasionally beats them is RockAuto. That’s assuming you don’t need the part ASAP.
I used national seals and MOOG ball joints. Previous owner installed knurled ball joints so had to stick with that. Pretty easy job (just time consuming) if you have a shop press. If you don’t, I’d call around and find someone you can bring the axle to to have them change the u joint.
Old May 11, 2019 | 05:59 PM
  #324
Hummer45Hummer's Avatar
Hummer45Hummer
3rd Gear
Originally Posted by EXv10
2000 EX with the V-10 and 135k miles. This is no typical steering/wandering problem so no need to reply with posts about springs, ball joints, tie rods, etc.
The front end jerks from left to right and you can take your hands off the steering wheel and see the wheel going right, left, right, left, etc. Sometimes it is worse than others and seems be get better when it warms up. It is impossible to control and looks like you might be drunk going down the road.
I searched posts for hours with no answers so it would be appreciated if someone knows what causes it. I did see a couple posts with the same problem but they had no answers.
There is something physically pushing the wheel left and right about once every second.
It's not the U-joints either because they are both spinning freely by hand and it is in 2 wheel drive. This problem comes and goes, sometimes it acts normal and sometimes the wheel almost violently jerks back and forth. It is usually worse when it is cold.
Rotate the tires first....front to back also do a fresh balance.
See if anything change.
If you notice things get better then you need new tires
Old May 12, 2019 | 04:03 AM
  #325
kxp7000's Avatar
kxp7000
Is is any diference when you press braking pedal? Or when you go fast then you start braking the car still going from side to side or you can feel diference betwen?
Old May 12, 2019 | 11:25 AM
  #326
Hummer45Hummer
3rd Gear
Rockauto and look for moog parts
Old May 12, 2019 | 01:59 PM
  #327
jdw1's Avatar
jdw1
So moog over spicer?
Old May 13, 2019 | 10:03 AM
  #328
Stewart_H's Avatar
Stewart_H
Just FYI, you're quoting a post that's over 10 years old.
Stewart
Old May 2, 2020 | 07:17 AM
  #329
quicker1's Avatar
quicker1
Guys,
I know this is an old thread but thanks for sharing all your experiences. As I read through this I thought for sure my problem was a pump or steering box. Then some started talking about front axle U joints and I thought "there's no way thats my problem.
As I was looking into changing my pump and steering box I found this video on how this often gets misdiagnosed. After watching it I checked my U joints and sure enough. One side of the right front axle u joint was seized just like in the video.
Thanks again for your help guys.
Old Jul 26, 2021 | 06:22 PM
  #330
quillen3257's Avatar
quillen3257
Did you figure out what was causing it?
Thanks everyone for your help, I guess I will have to take it to a shop when I can afford it to solve this mystery...............Brent
Did you ever figure out what the problem was?
may husband is experiencing the same exact thing.
