Electric Fuel Conversion
Old Feb 3, 2010 | 05:06 PM
  #46
Talyn's Avatar
Talyn
Sounds good Kevin. I'll look into the SD pump system.
Seems like the big components moneywise on this system is the regulator and the pump.
Then behind those would be the filter system.
Old Feb 3, 2010 | 10:37 PM
  #47
crash1's Avatar
crash1
so with that combo there do you need the pressure reg. then? or can you run strait from sd pump into stage ones .
Old Feb 6, 2010 | 04:20 PM
  #48
KevinC.'s Avatar
KevinC.
There is a lot of money in the filters and filter heads. The pump was only 140 and so was the regulator. I think the filters and heads were a little more than that. Theres a lot of money in all the fittings also, those things add up. Total cost was around 600.00.
Old Feb 8, 2010 | 09:43 AM
  #49
Talyn's Avatar
Talyn
Now just to get a better understanding of the systems, and I should be able to come up with something.
Old Feb 8, 2010 | 12:56 PM
  #50
FARM69's Avatar
FARM69
Does anyone have any good sources to SS braided hose (teflon rated)? It sounds like the crimp or push-lock fittings are the way to go on these. I'd rather use the 1/8 npt to jic fittings but I don't think they well fit because of the turbo mount.
Old Feb 8, 2010 | 06:39 PM
  #51
Talyn's Avatar
Talyn
In was thinking pushloc too as well.
Just for the simplicity also.
Old Feb 8, 2010 | 07:18 PM
  #52
crash1's Avatar
crash1
__________________
Old Feb 8, 2010 | 07:26 PM
  #53
strokersace's Avatar
strokersace
__________________
No you still need a regulator between the pump and the motor. And you can not use the stock fuel bowl/regulator because it's not built for an electric fuel pump that supplies pressure all the time. You'll want to delete your fuel bowl from the motor and add a 'spin-on' one between the pump and motor. Then on the motor, install an aftermarket regulator, like a Fuelab or Aeromotive.
Old Feb 8, 2010 | 07:36 PM
  #54
crash1's Avatar
crash1
I know its been said in here ,but the injectors run at 70 pounds right.Is there a ele. pump out there that can do this deal with out the reg. .Just a question dont yell at me please . llol
Old Feb 9, 2010 | 05:49 AM
  #55
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
60 - 65 psi is best. 60 is good all around. We actaully lost hp on the dyno going 70 psi and more.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 9, 2010 | 06:48 AM
  #56
tjbeggs's Avatar
tjbeggs
I don't know if their prices are inline but I know the people personally cause they are about 3 miles from here. But anyway Check out Chassis Shop. They are dune buggy parts people but they have all of the teflon/braid hose you could need and the fittings. They also carry prefabbed lengths.
Speed Flex Pre-Assembled Hose at The Chassis Shop
I think their catalog is online too browse that its full handy stuff!
Old Feb 9, 2010 | 10:35 AM
  #57
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Brain fart, deleted.
Old Feb 9, 2010 | 10:58 AM
  #58
tjbeggs's Avatar
tjbeggs
feeewwwhhhh that thing stinks!! better check your britches
Old Feb 10, 2010 | 12:34 PM
  #59
Gobstopper909's Avatar
Gobstopper909
William, i went with two sd pumps. one pump will do you good. howdy tim how are you?
Old Feb 10, 2010 | 12:49 PM
  #60
tjbeggs's Avatar
tjbeggs
Doing good!
