Electric Fuel Conversion
Old Sep 20, 2009 | 08:07 PM
  #31
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
I've been looking at this mod here and at a couple of other sites. I think I can do it on a budget by fabing, trading, and junkyarding. My questions are 1) Is this setup any different than a FASS or AirDog mfg one? 2) Does this setup remove air like FASS or AirDog? 3) After seeing the homemade setups and the costs, aren't FASS or AirDog cheaper? 4) What am I missing other than the enjoyment of creating your own setup? Thanks to any/all who answer my Q's.
Old Sep 20, 2009 | 09:22 PM
  #32
strokin'_tatsch's Avatar
strokin'_tatsch
i was actually wondering what to use to remove the air.. not sure if the CPR system removes air or not.
Crash1, that red mojig on top of the engine is the fuel pressure regulator. that one is an aeromotive unit and is adjustable. the factory system runs around 50psi of fuel pressure and we want ours around 65-70psi, but you can up the fuel pressure of a stock system very very very very cheap. one on the framerail is the pump he used. not sure what brand it was, but most of us use factory pumps out of super dutys with 7.3L's. you can also use dual super duty pumps for extra large injectors and what not
Old Sep 20, 2009 | 10:20 PM
  #33
crash1's Avatar
crash1
ah i see strokin'_tatsch Thank you.
Old Sep 20, 2009 | 10:24 PM
  #34
BlueMule's Avatar
BlueMule
Nope, the CPR is not an air separator. The only two that I know of are the AirDog and the FASS. They are both lift pumps that make less than 20 psi and to use them on a PSD you'd have to use a 2nd pump inline to bring the pressure up to 60-65 psi. On an OBS truck you'd also need to use a 3 port fuel valve so that you could return the air/fuel to whatever tank you were drawing off of.
Old Sep 24, 2009 | 10:57 PM
  #35
Gobstopper909's Avatar
Gobstopper909
does anybody know the part number or maybe what kind of hobbs switch i can use for my fuel restriction light? i googled it but theres a crap load out there. sorry to
Old Sep 25, 2009 | 08:55 AM
  #36
bodabdan's Avatar
bodabdan
Veteran: Navy
http://content.honeywell.com/sensing...reSwitches.asp
They show you a good chart here, but it is missing a little info. I'd say that if you knew the specifications for the switch you could get it.
You'll need to figure out what you want the setpoint to be, thread size/pitch, number/type/style of electrical connection, a diaphragm that's diesel/bio compatible, and voltage/amperage requirements.
If you can feed that info to the switch people they'll probably have it.
Old Dec 24, 2009 | 07:37 AM
  #37
crash1's Avatar
crash1
Whats the gph on the electric used there in the pics.
Old Feb 2, 2010 | 04:24 PM
  #38
Talyn's Avatar
Talyn
Some guys been posting bout electric systems lately.
This thread just kinda died out, but has a good idea/system for cheep.
Old Feb 2, 2010 | 08:06 PM
  #39
crash1's Avatar
crash1
where where
Old Feb 2, 2010 | 08:12 PM
  #40
Talyn's Avatar
Talyn
its an active thread right now.
your still wanting to go on this arn't ya curt?
I was thinking about buying the beans system, but if i can put this system together for 600 dollars. I can use it as an article on my websight, as well take a bunch of good pictures for everyone.
Old Feb 2, 2010 | 08:14 PM
  #41
crash1's Avatar
crash1
no no i found it lol
Old Feb 2, 2010 | 08:45 PM
  #42
FARM69's Avatar
FARM69
Yep... Someone posted a hot link in the thread I started yesterday.
I guess I was trying to determine the real differences between Beans and CPR....
Old Feb 2, 2010 | 10:01 PM
  #43
97-psd's Avatar
97-psd
william, you can definitely do this for less than 600, I did it for just a touch over 500, it is a nice upgrade from stock, and you know the best thing??? no fuel leaks!!!!
Old Feb 2, 2010 | 10:15 PM
  #44
Talyn's Avatar
Talyn
Ben, do you have a complete parts list?
I'll probably grab a bigger pump than you did. I wanna go overkill, but not like. 300cc injector overkill. haha.
I might just go with the super duty pump.
Old Feb 3, 2010 | 04:52 PM
  #45
KevinC.'s Avatar
KevinC.
Ive been using an SD pump for 15k miles with 180's. Works great
