Module problems?
Old Jan 23, 2009 | 10:50 AM
Carhoppers's Avatar
Carhoppers
Module problems?
I've been having problems with my 98 Navigator 4x2. From what i read online it sounds like its a common problem with Ford trucks, windows dont work, no interior lights, no defogger, or windshield wipers, etc..
I believe my fuseblock on the driver side or the general electronic module (i guess thats it?) or both are corroded. The problem is I need step by step instructions on how to get to them quickly and easily as possible. dont know if they can be cleaned or if they need to be replaced. I can c around my windshield wher it looks like water got in.
I bought this stupid Haynes manual for it and it tells u nothing! Thanks for any assistance rendered.
Old Jan 25, 2009 | 01:40 PM
Carhoppers's Avatar
Carhoppers
Hey guys, i know someone has had this problem. Need help badly, thanx.
Old Jan 25, 2009 | 02:31 PM
kailor's Avatar
kailor
Replace them or have them replaced. Dealer did mine 2 years ago for approx. $800.
Old Jan 25, 2009 | 05:01 PM
shorebird's Avatar
shorebird
You may want to start by trying a can of spray contact cleaner and giving them a good soaking then pull each fuse one at a time and replace it. Take each plug and disconnect it and spray the socket and plug with cleaner. Use some canned air or compressed air to blow the crud out of any connections.
Old Jan 26, 2009 | 02:40 PM
Carhoppers's Avatar
Carhoppers
Ok, but how do i get to fuseblock and the module. I read instructions online a while back on how to get to it in less than 30 minutes, but i cant find it anywhere now. I know its under the driver side dash somewhere thats all i know.
Old Feb 15, 2009 | 07:50 AM
doug1003's Avatar
doug1003
I have the same problem with my 97 F150 4x4. I have been driving with a bad heater core which may have blown something else. The windows, mirrors, interior lights, and wipers seem like a fuse problem. I'll look into the GEM thing.
Old Feb 15, 2009 | 12:42 PM
alloro's Avatar
alloro
Read this: http://www.justanswer.com/questions/1an1z-1999-ford-expedition-windows
Old May 30, 2009 | 10:11 AM
tatanick's Avatar
tatanick
I have a 2001 Expediton ED 4x4 with the same problem my windows won't work even the moon roof and interior dome lights and running board lights don't work. I replaced the fuse and relay same thing. I have a new Gem Module for it but how do I program it? It says it needs programing on it with a little yellow sticker. please help.
Old May 30, 2009 | 01:09 PM
alloro's Avatar
alloro
The GEM has to be programmed by the dealer.
Old Jun 2, 2009 | 05:56 AM
doug1003's Avatar
doug1003
Thanks, that is very helpful information. I took a blow dryer to the GEM and that seemed to solve everything except my passenger window gets ine roll down and one roll up a day. I think some mosture is still getting to it.
Doug
Old Jun 2, 2009 | 08:30 PM
alloro's Avatar
alloro
I had the same window not working issue but with the driver's side. It would not roll down, but if I applied power directly to the motor it went down fine. I could then push up and the window would go up normally, but again would not go back down. This happened after a good rain or a car wash. So I figured my windshield was leaking water into the GEM, which would dry out after a few day and the window then worked fine. Thanks to an (ahem, cough, cough) impact on my windshield, the insurance company paid for a brand new one. No more leak and no more window problem.
kpoyner
1978 - 1996 Big Bronco
Jan 28, 2024 09:25 PM
Jarryd
Oct 30, 2013 08:59 PM
mbair
Mar 23, 2011 08:44 AM
302lx
1997 - 2003 F150
Nov 25, 2009 06:58 PM
pscrow86
Nov 24, 2009 08:19 AM
