RABS problem
Old Oct 30, 2013 | 06:54 PM
Jarryd's Avatar
Jarryd
RABS problem
Don't know if it's the sensor or the module but my speedo is all over the place and my brake petal is fluttering when I step on it. It only makes sense that it's something in this system.
Old Oct 30, 2013 | 08:04 PM
Jarryd's Avatar
Jarryd
ABS light came on too.
Old Oct 30, 2013 | 08:50 PM
JReagan90's Avatar
JReagan90
I'm no expert on this issue, but from what I have seen there's a couple of different reasons that you could be having this problem. More than likely (as you have guessed), it could be the RABS sensor which also picks up the info on your speed which would explain your speedometer issue. When my truck was having a similar problem, it turned out to be all the old wires behind the dash had melted together. All that trouble was thanks do a prior owner who was a dummy and stuck a 30 amp fuse in a 15 amp slot because it kept blowing. Might be worth taking a peek at the wires to see what kind of condition they are in too. Hope this helps!
Old Oct 30, 2013 | 08:59 PM
Jarryd's Avatar
Jarryd
Well I recently installed a new rear end that had been in a flood. I left the sensor in it. Was going to swap my stock sensor in and see if that fixes the problem.
Jarryd's Avatar
Jarryd
If I'm going over 30ish, it seems to work fine.
bokker
3.8 & 4.2L V6
Oct 29, 2008 09:11 AM
550superdutytwinn
Feb 20, 2008 07:47 PM
jessfactor
Electrical Systems/Wiring
Jul 27, 2005 02:11 PM
tex1313
Oct 4, 2004 02:02 AM
merritdc
Jun 4, 2003 07:54 PM
