1978 - 1996 Big Bronco
Windshield washer not working
Old Sep 1, 2010 | 01:37 PM
kpoyner's Avatar
kpoyner
I have a 95 and my windshield washer doesn't work. The wipers work and when I push the button the wiper control module clicks. I have replaced it and it does the same thing. I have checked for voltage at the pump and there isn't any. I kind of think I got a bad module but wanted to check and see if anyone else has had this problem and fixed it.
Old Sep 1, 2010 | 02:20 PM
Encho's Avatar
Encho
The Southernmost Mod
Have you checked the line coming from the washer fluid reservoir to the washer?. Mine broke so atm i can't use the washers. My wipers are in good working order.
Old Sep 1, 2010 | 03:06 PM
American Thunder's Avatar
American Thunder
I can't remember what circuit the pump is on, does it have its own fuse or does it share the fuse with the wipers? Check it out, anyway.
Old Sep 13, 2010 | 08:33 PM
fastcatboat's Avatar
fastcatboat
i have burned up a wiper motor the hoses were clog i blow out all the hoses with a blow gun then i put i new motor everything work so check out the hoses the motor may be ok just the hose bad
Old Sep 14, 2010 | 12:43 AM
greystreak92's Avatar
greystreak92
Assuming the issue is electrical in nature, the fuse in question is fuse #2 in the dashboard fuse panel. It is a 30 amp fuse that runs the wipers AND the washer fluid pump. TO test the pump, check to see if you get battery voltage (approx. 12VDC) between the BLACK/WHITE wire on the pump motor in the washer reservoir and the frame of the truck. Obviously, you will have to have someone push the washer button to perform the test. If you get voltage but the pump doesn't run, well.... and if you don't get voltage the problem resides in the multi-function stalk. There is no relay for the washer pump motor.
On the other hand if you DO get the proper voltage at the wires in question, and you can hear the pump running, you might want to follow the suggestion already made to try cleaning or replacing the fluid line running from the pump to the nozzles in the cowl.
Old Jan 25, 2024 | 04:35 PM
bullskin's Avatar
bullskin
2nd Gear
I am having the same problem. Still trying to figure it out.
Old Jan 25, 2024 | 04:37 PM
bullskin's Avatar
bullskin
2nd Gear
I am having the same problem on my 1996 F 150. Still trying to figure it out.
Old Jan 28, 2024 | 09:25 PM
shorod's Avatar
shorod
There's not really much other than wire between the Wiper Control Module and the washer pump. If you checked for voltage to the pump were you using the pump's ground or a common ground? If using the pump's ground, try measuring for voltage with respect to a known good ground. If you were using a known good ground, then try checking for voltage at pin 4 (Black/white tracer wire) at the Wiper Control Module when the washer is activated. If you have voltage at pin 4 but not at the pump, then you have an issue with the wiring between the module and the pump. If you don't have voltage at pin 4, then you're going to want to confirm you have a short circuit between pins 7 (Brown/white tracer) and 9 (Dark Blue/white tracer) at the module while the washer button is pressed. If you do, then your issue is likely the Wiper Control Module. If you do not, then the issue may be with the Multi-Function Switch or the wiring between it and the module.
-Rod
phoneman91
64
Feb 2, 2025 05:40 PM
G. O. Mann
Jun 13, 2017 11:35 AM
82fordowner
Jun 9, 2016 10:57 AM
Ronnief150man
May 17, 2016 10:09 PM
Wyostroke91
Apr 25, 2013 07:39 PM
