Sponsored by: Auxito
transmission woes
Old Jan 16, 2009 | 02:45 AM
jerry.wm.mcguire's Avatar
jerry.wm.mcguire
transmission woes
I have a 2002 f150 small block 8, e4od trans and electric transfer case. since changing
speedo reads 160 kph actual 60kph and shift points way out don't get out of third help please
Old Jan 16, 2009 | 07:45 AM
Johnny Langton's Avatar
Johnny Langton
Which engine? 4.6L or 5.4L?
You've either got a 4R70W or a 4R100 in that truck.
What did you change that caused this?
JL
Old Jan 16, 2009 | 10:25 AM
jerry.wm.mcguire
transmission woes
JL
Johnny: I have a 4.6 L motor, I had a whole lot of 4x4 issues and the end result I went
to a wrecker and got a e4od trans and a electric shift transfer case since changing my
vehicle will go 60 kmph and show 160 on the speedo. I don't believe i"m getting out of 2 nd gear even at that speed. I don't relish a 600 km trip to a dealer to set up shift points or is this something else help help
Old Jan 16, 2009 | 12:16 PM
Johnny Langton
What trans was in it?
JL
Old Jan 16, 2009 | 01:11 PM
n3up's Avatar
n3up
I don't believe that the E4OD or 4R100 was used with the 4.6L.
Swapping the 4R100 onto a 4.6 that had a 4R70W will give you problems as the ECM is not compatible I believe...
Old Jan 16, 2009 | 04:05 PM
jerry.wm.mcguire
transmission trouble
you are right and boy was i wrong the trans i have is a 4r70w with an electric transfer case attached. the problem is my speedo says 160 and i am only doing 60 actual. no one in my part of the country has a program for the computer. I am assuming the wrecker gave me a tran and transfer case out of another vehicle that didn't have 17 inch tires and wasn't a 2002.
Old Jan 16, 2009 | 05:10 PM
n3up's Avatar
n3up
Did you use your original VSS or did you use the one that came with Trans/T-case?
Old Jan 16, 2009 | 05:27 PM
jerry.wm.mcguire
yes sir the original one is still in my truck, didn't think to ask wrecker for thst too
Old Jan 16, 2009 | 06:49 PM
jerry.wm.mcguire
yes the original vss is still in my vehicle, what do i do now this was changed in july or august 2008. can only drive out on winter roads in my part of the dcountry northern manitoba
Old Jan 16, 2009 | 08:11 PM
n3up's Avatar
n3up
I was thinking that the speedo error was caused by a wrong VSS, but if you used your original it rules that out.
The drive gear on your t-case is probably different.
Do you know what year the trans/t-case came out of?
It sounds like you need to get the right combo of drive/driven teeth.
Old Jan 16, 2009 | 08:35 PM
steve(ill)'s Avatar
steve(ill)
i cant help you, but i would not think the speedo gears. you are 300% off. gears or wheel size could account for 10-20%. I would bet the computer is setup different for a EO4 compared to the newer 4R70W. Your not close, something is WAY off. I would guess your going to need a reprogram at the dealer.?? maybe a call to them or trans upgrade shop could confirm that.
Old Jan 16, 2009 | 09:02 PM
jerry.wm.mcguire
Thanks Guys For All The Help I Think I'll Make The Trip To Winnipeg At A Slow Speed To Get Reprogrammed
Old Jan 19, 2009 | 07:49 PM
DarrinBC's Avatar
DarrinBC
I am curious as to what year transmission was installed.
Darrin
dorkpunch
General Automotive Discussion
207
May 19, 2016 07:59 AM
Rocky Mountain Jeff
May 11, 2011 04:34 PM
Kusca
Oct 10, 2010 11:09 PM
logger250
15
May 5, 2010 01:58 PM
Horse lover
1997 - 2003 F150
Apr 21, 2005 04:02 PM
