strokers
Old Nov 14, 2008 | 07:28 PM
late70sfordnut's Avatar
late70sfordnut
strokers
who has built a stroker out of a 460 not looking for a 800 hp maybe 450 500 without braking the bank
Old Nov 14, 2008 | 08:08 PM
monsterbaby's Avatar
monsterbaby
what are you wanting to know? I have built a stroker but it is over 900hp.
Old Nov 14, 2008 | 08:19 PM
mwvdub's Avatar
mwvdub
i have one also. more info please
Old Nov 14, 2008 | 09:33 PM
late70sfordnut
here latly i have heard of about a 534 stroker, put together with basicly stock parts, and just the basic machine work. boring a block 80 over how long will that last , isnt ther heating problems
Old Nov 14, 2008 | 09:38 PM
monsterbaby
it's actually a 532, 4.3" stroke, 4.440 bore (.080 overbore) it is done a lot but best to sonic test the block first. a lot of the blocks will go that much but I wouldn't trust a block without a sonic test personally.
As to using stock parts?? well not really, aftermarket crank, rods and pistons. I know you can get cast steel cranks pretty reasonable, set of eagle or scat Hbeam 6.8" rods and off the shelf pistons or you can by a rotating assembly from several different places easy enough. Me personally I would just do a 521 (same combo except only .030 overbore) wouldn't have to worry about the sonic test.
Old Nov 15, 2008 | 09:37 PM
late70sfordnut
what kind of easy hp can you pull from the 521
Old Nov 16, 2008 | 12:41 AM
monsterbaby
400-700, thats way to open of a question it depends on what your willing to spend, what heads you want to run, if you want to run race gas or pump gas, do you need to pull vacuum, on and on. You really need to be a lot more specific if you want answers for stuff like that.
Old Nov 16, 2008 | 01:29 AM
bucks77ford's Avatar
bucks77ford
I'm running Trickflow Aluminum Heads so that was $2K and the stroker kit was $2K on my 521. That was just a start. I didn't get a chance to have it dynoed, so I'm not sure of the HP/Torque.
Old Nov 30, 2008 | 08:26 AM
werneil's Avatar
werneil
hi, why not just build a mild 460 to easily make 500 hp
Old Nov 30, 2008 | 02:27 PM
peganit2's Avatar
peganit2
Ttrue. If you're on a limited budget just build a stock stroke 460. Get some SCJ heads or P51s from Kaase, build it right, and you'll make more power then you thought you needed. 500-600hp, with 500+ ft/lbs of torque is easy with 460c.i.
And all you want is 450.
And it'll rev like a small block.
MER
18
Nov 30, 2008 09:07 AM
zach2004
Aug 14, 2004 08:53 PM
Mechanix185E
19
Jun 23, 2003 11:50 AM
xyfalcon500
Mar 2, 2002 10:23 PM
BJs77F150
Jun 2, 2000 04:48 PM
