I had the wiring harness and glow plugs changed on my '97 F-350 and it ran fine for a bit. I really don't drive the truck that much at all but recently when I did she stopped running for some reason. It seems that glow plug relay and the fuse that controls the fuel pump have blown. After replacing them the truck seems to run fine again until they blow seemingly randomly. Any suggestions as to what may be causing this?
If that isn't it which fuse are you blowing? if you have a 97 or older PSD it has a mechanical fuel pump. Let us know which fuse and that will help us track it down. BUT fuel heater is probably the issue
