99 f350 blowing glow plug fuse
Originally Posted by 4dtough
my fuel heater fuse blows as soon as I turn the key on, any suggestions?
What's the resistance across the heater? You may be able to repair yours if it isn't a dead short. It may have shorted directly to ground and only need some form of insulator to be functional again.
How many watts do you believe are necessary for this device to generate? 35? That would be a resistance of around three-tenths of an ohm. More wattage is lower resistance. A quarter ohm would be around 50 watts. Those should give you some ballpark figures of the unit's resistance when new. Of course, it may even twice the wattage and half the resistance. The resistor you describe is logically the heating element itself.
I have no idea what these look like, and I'm not going to pull mine out to see, but you may investigate and save yourself some money.
Pop
Pop
Anybody have a picture of this heater out of the housing?
The normal failure mode for a resistive heating element is to open, not short. It can short to something adjacent, however, and be a short to ground on the hot side of the element.
Something sounds amiss for the heating element, itself, to be shorted.
Pop
Pop
Well,
I gotta' think that that "center support bracket" (if that's what it is) is the logical place for a breach of the element's insulation, causing the resistance to drastically drop, in this case to under half, thus doubling the current draw, and blowing the fuse. But unless the element has actually gone open, it is likely still OK.
At any rate, even Ford shouldn't charge $150.00 for the element, unless they are, indeed, "stealers". $25.00 seems a fair price, however, to not have to mess with hi-temp insulating tape. The right insulation might cost that much. ;-)))
Thanks, Cookie. It helps the understanding.
Pop
Pop
ralleyclimber
04-28-2014 11:30 AM
