need help identifying a sensor
Old Dec 3, 2011 | 06:27 PM
rodent84's Avatar
rodent84
I have an 84 f250 w/6.9l.The truck won't start.The glow plug light was not comeing on so I checked the system and found a blowed inline fuse(looks like someone replaced a fuse link with an inline bar fuse)anyway i tried to replace the fuse and it blowed as soon as i turned the switch on.The fuse is feedind to the gp controller and what looks like a temp send unit on the front passenger side of the motor screwed into the intake right behind the radiator hose inlet.It has two prongs on it.When i unplug it the fuse stops blowing and my glow plug light coms on.Does anyone know what this sensor or whatever is and what it does?
Old Dec 3, 2011 | 07:23 PM
dakotajeep's Avatar
dakotajeep
Its the temp sensor that the Glow Plug System uses to determine how much time to run the glow plugs for.
Not sure why yours is having issues. Read up as much as you can on here....
Thad
Old Dec 3, 2011 | 07:43 PM
rodent84's Avatar
rodent84
Thats what i thought it was but i've tried to find a new one online but everything i look at only has one terminal plug on it
Old Dec 3, 2011 | 07:58 PM
rodent84's Avatar
rodent84
I think it's called a glow plug sensor but still haveing problems finding one,Found it on ebay but i would rather buyit from a parts store
Old Dec 3, 2011 | 09:17 PM
starmilt's Avatar
starmilt
That has nothing to do with the gp's, that is the switch for the cold start advance and the fast idle solenoid. It doesn't even have to be hooked up to run.
Old Dec 4, 2011 | 05:58 PM
cornking's Avatar
cornking
This is just my experience. When my sensor came undone, my glow plugs would only cycle for 5 seconds. When I re-attached it my plugs cycled for 10 seconds. It must have something to do with the glow plug system.
Old Dec 4, 2011 | 07:56 PM
starmilt's Avatar
starmilt
I know on the 86 down system it has nothing to do with, the glowplugs, and I don't see how it could have anything to do with the later system. It is a switch that gives power to the cold start advance and and the fast idle solenoid until the water temp is 112 degrees.
So it is either on or off at 112, I don't see how it could affect gp times. The controller for his 84 is on the very back driver side of the engine.
Old Dec 4, 2011 | 08:40 PM
Aune163rd's Avatar
Aune163rd
its the same as the 86. i know htat for a fact...
Old Dec 4, 2011 | 08:55 PM
starmilt's Avatar
starmilt
Yep.......
Old Dec 5, 2011 | 07:21 PM
jb10725's Avatar
jb10725
Is the wires that the fuse holder is connected to a red wire with a light green stripe? If it is, according to my schematic, that wire comes from the ignition switch (or a relay powered by it), through the fuse (what used to be a fusible link), and it feeds the GP controller its ignition input along with the fuel heater, paralleled off of that to the fuel cutoff on the injector pump, paralleled off of that to the engine temp switch you mentioned, through it to the cold fast idle and cold advance solenoid on the injector pump. Is by chance the fuse too small? Someone might have put that fuse in the summer time, and now that it's getting colder outside, it's got extra current through it because of the fuel heater. Actually, according to my schematic for your truck, unless the wiring has been modified from how it came factory, if that fuse blows the truck shouldn't even run because it's also the power circuit to everything on the IP.
Old Dec 5, 2011 | 08:40 PM
starmilt's Avatar
starmilt
I don't know how much juice the fuel heater uses, but I don't think it varies with the temps. I'm not even sure I have ever owned one that worked, as no bigger than they are there is no way they can heat the fuel as fast as it is burned, to me they are basically on there for looks.
Old Dec 5, 2011 | 08:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
its not meant to heat the fuel,just meant to keep the fuel filter warm so that doesn't plug up from gelled fuel in winter months.
iv had it happen once.diesel 911 took care of it though.
it was however a real nasty water filled batch of fuel.
fuel heater inop on mine too.
now iv got a coolant filter right next to it,so iv got to wrap the two filters together.that should work better than the little stock expensive fuel heater anyway.haven't gotten around to this yet lol.but i do have some 911 in the toolbox now.
(which works super fast just poured into the tank with the e-pump running fyi.10 mins she was back in action.could of just done road side had i known.)
Old Dec 5, 2011 | 09:43 PM
starmilt's Avatar
starmilt
They gel worse when they are parked, the returning fuel actually helps with that.
If they do gel when they are dead I don't see that the fuel heater is going to help anything, as the fuel in the ip, the inj. lines and injectors is the problem with starting .
Old Dec 6, 2011 | 08:05 AM
dakotajeep's Avatar
dakotajeep
When I initially read this I thought he was refering to the drivers side...I should read better next time.
Thad
Old Dec 6, 2011 | 08:41 AM
jb10725's Avatar
jb10725
I got curious and checked the current draw of the fuel heater on my truck this morning. When it was on, and the glow plugs on at the same time, truck not running, it was drawing about 3 amps. If the glow plugs weren't cycling or the truck was running, it probably would have been slightly more since the voltage would have been slightly higher. The fuel heater has it's own internal temperatue switch that closes at about 30 degrees F. That's why I was wondering what size fuse the OP was using. I guess there is also the possibility of a shorted to ground temperatue sensor or wire, or even the possibility of an internally shorted fast idle or cold timing advance solenoid blowing the fuse. I don't know how effective these heaters are anyway, but I guess they can't hurt.
