I need to remove the lower panel that contains the door to the fuse block.
I see two (2) screws on the bottom, but is there a surprise in store for me to get the top of the panel loose?. Thought I would ask B4 I break something else.
Rog, Just threw this together for you. The arrows are a "clip". What I did to remove was carefully pry up with a small flat head screwdriver from the last arrow on the right and pull. Hope this helps!!
Haha only took like 10 seconds on paint but thanks for the rep points
c00n, Top switched are for Fog lights and T/C lock, **** is TS... Well TW as of tomorrow chip, Bottom two are backup lights, 1 switch per set of backup lights. Everything on seperate fuses so I know what went wrong if something did...
c00n, 2 sets of back up lights, totaling 4 total (check out 2stroke's thread on lights) sometimes i have the one under the bumper on, but not the ones on back rack so i can work in toolbox and not be blinded
and yes do have to watch out for them snow snakes... the'll bite ya!
