Horn
Old Mar 6, 2008 | 07:59 PM
Vinford's Avatar
Vinford
Horn
1994 F-350 XLT Dually 4x4 PSD
My horn wont work?
I put a hot wire to the horns and they work.
Where to start?
Thanks.........................
Old Mar 6, 2008 | 08:28 PM
kawa's Avatar
kawa
#1 Fuse
#2 Meter to the wire at the horn and have some one push the horn button
#3 Bump
Rog
Old Mar 6, 2008 | 08:30 PM
Vinford's Avatar
Vinford
Bumps dont do it our roads are full of them............
How about the daytime running lights?
Does anyone know where the box is that controls them?
Old Mar 6, 2008 | 09:16 PM
kawa's Avatar
kawa
You said the horn didn't work how did we end up on day runny lights????
Rog
Old Mar 6, 2008 | 10:21 PM
Vinford's Avatar
Vinford
Didnt want to start another whole thread for the lights.
Wasnt having much luck with the horn and I*m trying to fix both?
Old Mar 7, 2008 | 12:46 AM
Vinford's Avatar
Vinford
Now the speedo quit?
Looks like Ive got something electricial happening?
The speedo must be electric is it?
Old Mar 7, 2008 | 09:02 AM
iasrap's Avatar
iasrap
Yep speedo is electric. I would suspect you have a bad horn relay to fix your horn problem. Still looking over my EVT to figure out the speedo.
Possible theories...
1. Replacing the horn relay will fix the speedo too. (long shot) if the relay on the horn went bad, it might be grounding your Programmable Speedometer/Odometer (PSOM) through speed control, so no current is flowing to it. (if Odometer/trip is no longer displaying in addition to speedo not working this would support it fixing speedo too. However I do not have diagrams detailed enough in my EVT manual to get into the cicuitry of the PSOM and could not tell you for sure.)
2. Rear axle speed sensor could have gone bad. It should be the sensor on the top driver side of the differenial (if your odometer/trip is still working it would support this one or theory 3)
3. Your speedo itself died.
Always always always!!! check all connectors first for proper fit before thinking about replacing parts, and test the parts you have before replacing them.
Old Mar 7, 2008 | 09:29 AM
iasrap's Avatar
iasrap
Daytime running lights module is behind the driver side light assembly.
Old Mar 7, 2008 | 09:53 AM
Vinford's Avatar
Vinford
Wheres the horn relay?
Thanks
Old Mar 7, 2008 | 09:59 AM
Action4478's Avatar
Action4478
Its # 3 under the hood ....
try switching 3 & 4 around & check fuse # 3....30 amp....
Old Mar 7, 2008 | 12:27 PM
Vinford's Avatar
Vinford
Horn relay not the problem.
Checked it as suggested.
When you take the cover off the steering wheel should there be juice in the wires that plug into the steering wheel cover?
I have none.
Old Mar 7, 2008 | 09:26 PM
Vinford's Avatar
Vinford
Its gone beyond the horn.......
I found a fried light switch that someone has stuck a hot jumper wire into . The plug is fried not the switch.
I found a little black box bolted just below the drivers side hood hinge.
It has a wire going from the power box on the fender into it , a ground and 3 wires coming out of it.
2 of the 3 wires coming out of it have been cut off.
Ive got some major problems here I think and need all the help I can get so if anyone has any ideas about any of it please let me know?
How hard to change the whole underdash wiring harness , has anyone done it?
Thanks
Old Mar 8, 2008 | 09:30 PM
Vinford's Avatar
Vinford
Nobody knows where I can look for a new harness or how hard they are to change?
Old Mar 9, 2008 | 11:01 AM
c00nhunterjoe's Avatar
c00nhunterjoe
a whole under dash harness is going to be a ford only item but i doubt they still manufacture it, long shot but give them a call.
other then that its going to be repair yours or a junk yard unit.
if it were mine i would repair the one i have
Old Mar 9, 2008 | 09:51 PM
Vinford's Avatar
Vinford
Im bidding on a harness on Ebay.
It says its for a 95-01 I hope 94 is the same. Its a long shot but Ill try and get it bought as the trucks a great truck and Id like to fix it right!
