I know that to remove the lower knee panel under the steering wheel all that has to be done is to pull it off and the attachment snaps will pop free.
However, How do I go about removal of the dash panel to the left of the steering wheel? This would be the narrow panel that also houses an ac vent, headlight **** and I believe it is the adjustable pedal control.
Do I need to pop off the ac vent trim ring or remove the **** from the headlights pull or anything?
Just tried mine again and it did not move. I can't remember if I removed dash bezel next to it to uncover screws or not. Sorry, I'm of little help. I have had it out but don't remember exactly how.
Ince you pop off the one under the steering wheel you will see one or two bolts holding the left side on. Remove them, then it will pull right out. No need to remove the ac vent trim. This is actually done after the panel is off by the way.
