Pyrometer ???
Old Oct 25, 2007 | 07:49 PM
dogman's Avatar
dogman
Pyrometer ???
Inlighten me, I'm having a brain fart here. Installing a Pyrometer in front of turbo or behind turbo. I understand the in stall in front so you know what the temp. is before the turbo, BUT you will have the same readings behind the turbo and a lesser chance of something getting into the turbo to. So is the brain thinking right here?
Old Oct 25, 2007 | 08:13 PM
720Deere's Avatar
720Deere
The readings pre vs post turbo pyro are at least 200 degrees higher. By the time the turbo deals with the exhaust and acts like a heat sink, the EGTs have dropped off significantly. Big rigs are all post turbo and there is no problem with that, you just need to know what to base your safe max temperature on.
Old Oct 25, 2007 | 08:31 PM
bismic's Avatar
bismic
As I understand it .............
Pre-turbo to have the most accurate reading to know when to "back off" of the throttle.
Post-turbo to know when it is safe to turn off engine after towing hard (never shut down after heavy towing with out a cool down period)
Old Oct 25, 2007 | 11:31 PM
LvTitan's Avatar
LvTitan
you will get different readings depending on pre/post turbo.
for engine vitals monitoring you will want to mount your thermocouple probe BEFORE the turbo, the post turbo readings are closer to 400 degrees less due to the heat energy absorbed by the turbo itself.
only reason for post turbo is for cool down function, but if you wait till preturbo is under 400 for a few minutes you should be good to go.
Old Oct 25, 2007 | 11:56 PM
blackhat620's Avatar
blackhat620
dogman,
Pre-turbo is the way to go, the post turbo temps can vary up to 400F lower but it is not linear. So post turbo temps are not an acurate measure of pre-turbo temps, and pre-turbo temps are important to maintain safe combustion temps. Also the odds of an inconel temp probe breaking off are slim to none.
Here is a link to install photos
http://www.dieselmanor.com/diy/PSD3-...60gauge-p1.htm
Old Oct 26, 2007 | 05:53 AM
dogman's Avatar
dogman
Now that my head is on right. Thanks guys. Blackhat, Thanks for the link. I was looking for info that.
Old Oct 26, 2007 | 10:00 AM
jimmy-six's Avatar
jimmy-six
You can get a dual gauge and do both. Units like a Bully Dog moniter can do 2 and give you additional info like volts, real boost pressure, etc....Good Luck
Old Oct 26, 2007 | 01:21 PM
geeride's Avatar
geeride
Good info. Thanks also!
Schmitty133
Feb 5, 2015 07:58 PM
Bowie
Sep 15, 2009 05:18 PM
pdx02
Mar 26, 2009 02:28 PM
XxfirmanxX
Dec 20, 2005 05:04 PM
edub32
Apr 5, 2005 08:20 PM
