Post turbo pyrometer ?????
Old Sep 15, 2009 | 01:05 PM
Bowie's Avatar
Bowie
Ok, so now that I have the Preturbo pyrometer installed I am wondering if there is any use for the post-turbo one that is already installed on my exhaust piping. I bought the truck with a banks system already on it and I am in the process of taking it off.
What do you guys think is there any reason to know the post turbo temps if I already know the preturbo?
Also I wonder if the post turbo pyrometer will work if I was to buy a ISSOPRO gauge for it? Right now the temps are displayed through the 6 gun tuner.
Old Sep 15, 2009 | 01:18 PM
superduty4x4's Avatar
superduty4x4
I don't see the need to keep the post turbo pyro... remove it and plug the hole.
Old Sep 15, 2009 | 01:43 PM
farmdad's Avatar
farmdad
If you would want to know what the exhaust temp is of the air coming out of your turbo prior to shut down, go ahead and use the post turbo pyro. Since you have the pre turbo, that is about the only use you would have for the post. You will have to do some research to see if the probe will work on the ISSPRO gauge.
Old Sep 15, 2009 | 03:30 PM
Pocket's Avatar
Pocket
If you don't already have a spare gauge lying around... don't waste your money. It's fun for the first 5 minutes to see the huge temp variances, and after that you really won't look at it again.
Old Sep 15, 2009 | 03:34 PM
Bowie's Avatar
Bowie
What will work for a plug? Just any that fits and that is metal?
Old Sep 15, 2009 | 03:53 PM
Pocket's Avatar
Pocket
I'm assuming it's the typical welded bung that's threaded... if so, then yes just bolt in a plug and you're good to go.
Old Sep 15, 2009 | 04:09 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
About all it is good for is a Turbo Monitor if you run hard or pull heavy and don't want to wait for it to cool down.
Old Sep 15, 2009 | 05:18 PM
Bowie's Avatar
Bowie
Welded Bung ehh. Interesting.
Yes I believe it is that type. Never really heard that verbiage.
Clay do you think it will work with other gauges?
clydesride
15
Feb 14, 2012 02:18 PM
XxfirmanxX
Dec 20, 2005 05:04 PM
Rodslinger1
Apr 22, 2005 08:32 AM
edub32
Apr 5, 2005 08:20 PM
Motoxman_117
Feb 3, 2003 06:48 AM
