5.4 plug issues
Old Nov 26, 2007 | 05:25 PM
  #121
Hematite's Avatar
Hematite
I believe the 4.6 in the Mustang is a 3V engine starting in 2005. I thought that the 4.6 in the F150 was also changed to a 3v engine, maybe it wasn't. I don't recall hearing about this problem in the Mustang 4.6 3V but maybe I'll check some of the Mustang forums and see.
Old Nov 26, 2007 | 05:27 PM
  #122
wreedZ71's Avatar
wreedZ71
[edit] 3-valve
The 3-valve SOHC 4.6 L with variable camshaft timing (VCT) first appeared in the redesigned 2005 Ford Mustang.
The engines are equipped with an electronic Charge Motion Control Valve (CMCV) system that regulates the flow of air into the intake ports. Block material varies between the aluminum block used in the 2005+ Ford Mustang and 2006+ Ford Explorer and the iron block used in the 2004+ Ford F-Series (see below), though aluminum heads are used in all applications.
The 3-valve SOHC engine was on the Ward's 10 Best Engines list for 2005 through 2007.
Vehicles equipped with the 4.6L 24-valve SOHC include the following:
2005+ Ford Mustang, 4.6 L, 300 hp (224 kW) and 320 ft•lbf (434 N•m)
2006+ Ford Explorer, 4.6 L, 292 hp (218 kW) and 300 ft•lbf (407 N•m)
Old Nov 26, 2007 | 06:03 PM
  #123
Hematite's Avatar
Hematite
Thanks wreedZ71 for the 4.6 3V info.
Well it turns out the 4.6 3V has the same problem as the 5.4 3V. After I don't know how many pages on a Mustang site, I found the exact same removal procedure for the 4.6 3V spark plugs as the 5.4 3V engine. Apparently, all the 3V engines, except the 2008 5.4's, have this "problem".
Mcrafty1
Modular V8 (4.6L, 5.4L)
Oct 25, 2014 01:20 PM
shore
1997 - 2003 F150
Jan 22, 2014 05:26 PM
mikeo0o0o0
2004 - 2008 F150
Jul 1, 2012 08:07 PM
JM48
2004 - 2008 F150
Nov 10, 2010 02:25 PM
SmokinBarrel
1997 - 2003 F150
Feb 14, 2010 02:21 PM
