5.4 plug issues
Old Nov 15, 2007 | 10:30 PM
  #91
KevinAH's Avatar
KevinAH
I drive A LOT of miles. My job requires me to travel(drive) about 2k-4k a month. I tow consistently but not a lot of weight, 4 to 6k lbs. I occasionally carry light to moderate weight in the bed. My personal time takes me to the mountains and four wheel drive is used regularly. I change my oil every 3 to 4k miles and I maintain all my fluids at appropriate times. Oh, also, my truck still drives just like it did when it was new, except prior to getting the plugs changed it was pretty rough. Now it's new again. Oh, one more thing that's odd with this one, I had to replace the "pcm" at about 100k miles. Not related but noteable.
Old Nov 15, 2007 | 10:32 PM
  #92
stratus225's Avatar
stratus225
Originally Posted by Edge68474
Speaking of fuel, in the winter, don't the gas stations use more of an ethanol blend? Which I hear gives lower gas mileage. What about carbon deposits with ethanol?
I hear that they use ethanol in the winter for emissions. Summer, it's ok?
Have I given you my thoughts about politicians.
LOL. I'm sure we all have the same opinions, or close anyways.
The only company in Canada that I know of that uses ethanol (year round) is Mohawk. Petro Canada, one of the big three in Canada uses an additive for the winter but it is not ethanol. I have been telling customers for years to stay away from ethanol blended fuel as it seems to cause alot different driveability issues but not sure about excess carbon build-up. Anyone else with a thought on this?
Old Nov 15, 2007 | 10:35 PM
  #93
stratus225's Avatar
stratus225
So by the sounds of it....anything but 10-15 mile trips in stop and go traffic. That kinda blows my theory all to hell.
Do you fill up using the same fuel all the time Kevin?
Old Nov 15, 2007 | 11:30 PM
  #94
04 FX4 Lineman's Avatar
04 FX4 Lineman
Originally Posted by stratus225
Unfortunately Lineman, I work at a Saturn Saab dealer and this is the first 5.4 we have worked on, and only because its my truck. The tech that worked on it did read the bulletin, but if you have ever changed a spark plug, you can tell how much resistance is too much. So he just "felt" his way through it and no issues. Tah-Dah! If my truck is any indication of how these plugs are at 40k (kilometers) i dont think you will have an issue, but one thing my shop foreman reminded me of sticks out in my mind.....Canada seems to have better fuel than in the U.S. and it has been tested and proven....and he is also under the strong belief that is the additives in the fuel that can cause more or less carbonization of the engine, along with driving habits of course. So maybe we should all be polling on how many instances of plugs breaking are happening north and south of the border and what the driving habits of the worst case scenarios....for example Kevin, since yours seems to be the worst horror story here, what are your driving habits, short trips, no towing etc etc.....just my two cents.
Thanx strattus actually I am in the US Wa. state but I do a lot of slow driving Iuse only major brand fuel but in the winter all our fuel is oxygenated (ethanol) so we have no choice no matter what brand u use, so am thinking I will get mine changed soon and just see what they look like will have my ford dealer do them just to be safe.
Old Nov 15, 2007 | 11:41 PM
  #95
stratus225's Avatar
stratus225
I think thats a pretty good call Lineman. Small price to pay now for the possibility of the nightmares later. I would suggest that you ask for the old plugs back- uncleaned (alot of techs will clean old parts if customers ask for them back) just to see how bad they really are carboned up.
Old Nov 16, 2007 | 12:32 AM
  #96
KevinAH's Avatar
KevinAH
I typically will get fuel at a Shell or Chevron since they are most convenient. For a while I did use ARCO as that was where my company issued fuel card was for. I always use either 89 or 92 octane since I have an edge.
Old Nov 16, 2007 | 08:23 AM
  #97
tomclem's Avatar
tomclem
I'm still waiting for someone to find and show that a fuel additive that is specific to dissolving carbon works for removing any carbon that develops b/n the plug shield and cylinder wall. There has to be something that can work wonders if put into the combustion chamber where it is exposed to the plug and walls.
Old Nov 16, 2007 | 08:37 AM
  #98
stratus225's Avatar
stratus225
I'm wondering if maybe the next person to have the plugs changed should try a fuel/throttle purge a day or two before the plugs get done. This may help get rid of the carbon in a big way........
Old Nov 16, 2007 | 12:33 PM
  #99
04 FX4 Lineman
I am going to do exactly that I am interested is seeing what they look like??
Old Nov 16, 2007 | 02:56 PM
  #100
HamerDown's Avatar
HamerDown
All's that will do is maybe clean the Plug end...won't do anything for removing the carbon build-up in that tight bore and around the shield.
Old Nov 19, 2007 | 10:51 PM
  #101
05fx4Screw's Avatar
05fx4Screw
well did mine to this past weekend. Thanks again to DMAC66 for the links to parts. Did not read the Ford TSB or have any special tools just know how of how to wrench. Had it done in about and hour and a half. No problems did have the cracking noise but nothing i haven't heard before. Hardest thing is having a lifted truck and doing this. But i do rock crawling on the side and as a hobby so I'm always breaking something on my jeep and trying to find new way's to build it better. (wheel it, break it, build it better) Thanks for all the input guy's good to have a place to go to learn from.
Troy R.
Old Nov 20, 2007 | 08:04 AM
  #102
vpsr6's Avatar
vpsr6
I have a quick question on the nickel anti sieze. I got my Permatex bottle yesterday. It is very thick is this a trait of the nickel , I would say it's about twice as thick as tootpaste. The regular anti sieze is usually a little thinner than that. Thanks
Old Nov 20, 2007 | 11:55 AM
  #103
MBBFord's Avatar
MBBFord
The regular anti seize is mostly greese, and the nickel anti seize is grease, but with a lot of small nickel particals in the grease makeing it thick.
It should be a little thicker, but mine(nickel AS) doesn't seem that thick....., just a little thicker than the regular stuff(AS).
Old Nov 24, 2007 | 09:26 PM
  #104
baitmaster's Avatar
baitmaster
Stratus, I think you have a valid point on quality of gasolines in certain areas of the country. I also believe if you consistently use the cut rate gases you will have more probs overall. I recently changed plugs on my '97 Jeep that had almost 40,000m on them, and they looked brand new. I put them back in, OBTW I use nothing but Chevr*n and Sh*ll. Whenever I decide to change the plugs on the '05 150, I dont think I'll have any probs.
Old Nov 24, 2007 | 09:30 PM
  #105
baitmaster's Avatar
baitmaster
Anyone seen the info mercial on this Z-something stuff? He drops a chunk of carbon into a few drops on it, and the carbon vaporizes. Supposedly it also soaks into the metal. Carrol Shelby endorses it.
