Intake CFM shootout
Old Sep 5, 2007 | 11:44 PM
  #121
coolair's Avatar
coolair
FTE Sponsor
Wow, Cowboy Steve! We are talking about filters, Yes? Cotton vs Poly vs Paper? Volant is running Powercore technology! Let's do the math? Narrow it down to something specific? Let me know what you need to learn, I have a pretty smart team behind me!!! Maybe not as funny but just as smart
Bill
Old Sep 5, 2007 | 11:46 PM
  #122
powerstroked162's Avatar
powerstroked162
Can any of your intakes meet or beat what Im puttin down on the dyno right now with the 6637 filter? If so then lets set somethin up, trial period perhaps?
Cowboy Steve
Old Sep 5, 2007 | 11:53 PM
  #123
coolair's Avatar
coolair
FTE Sponsor
Thats Easy! But if you are pulluing over 11 or 12 hundred CFM's. Are you Getting what you need? We buy all our filters from***. Powercore are filtering 1500HP Turbin Motors. We are stepping up!!!Let me know what you need, We might suprise you!
Old Sep 5, 2007 | 11:54 PM
  #124
mech2161's Avatar
mech2161
I want to see the flow numbers of the 6637 compared to the Powercore technology.
Old Sep 5, 2007 | 11:55 PM
  #125
powerstroked162
^^^Ditto^^^
Cowboy Steve
Old Sep 5, 2007 | 11:56 PM
  #126
mech2161's Avatar
mech2161
I believe the K31 I'm running is in the 1350 cfm range.
Old Sep 5, 2007 | 11:58 PM
  #127
powerstroked162
my D66 is in the 1100cfm range
Cowboy Steve
Old Sep 6, 2007 | 12:00 AM
  #128
mech2161's Avatar
mech2161
I want a filter 10 inches long 8 inches round with a 4 or 5 inch inlet.
Old Sep 6, 2007 | 12:06 AM
  #129
mech2161's Avatar
mech2161
OK surprise me. I've got room on the side of the truck and my website.
Old Sep 6, 2007 | 12:13 AM
  #130
coolair's Avatar
coolair
FTE Sponsor
Thank you for the challenge!!! Give me till next week? I will give the straight ****
Talk Soon!
Bill
Old Sep 6, 2007 | 12:15 AM
  #131
powerstroked162
Talk Soon!
Bill
Its a deal
Cowboy Steve
Old Sep 6, 2007 | 12:33 AM
  #132
ernesteugene's Avatar
ernesteugene
Originally Posted by powerstroked162
Ok I ran the dyno today with the Tymar, AFE, and open element. Wanted to know for myself what was what so here are the specs:
3 runs with the tymar netted:
1st run on #2=413.7rwhp
2nd run on No2=481.1rwhp
3rd run on No2=481.3rwhp
3 runs with AFE stage2 netted:
1st run on #2=407.0rwhp
2nd run on No2=473.1rwhp
3rd run on No2=472.9rwhp
3 runs with open element netted:
1st run on #2=424.9rwhp
2nd run on No2=493.1rwhp
3rd run on No2=492.3rwhp
This is how I see the data. 1) Forget the AFE as it didn't fare well at all. 2) Your tymar cost you 11.4 HP, averaged over 3 runs, compared with no filter, which is what I'm assuming the 3rd run means, otherwise buy that "open element" filter. I'm a little confused, because I've always seen any filler that wasn't enclosed in an air box referred to as an "open element" filter.
Evidently the restriction of the tymar is costing you 11.4 HP. I'm wondering why you don't seem to be interested in getting some or all of that lost 11.4 HP back? Look at the pic below, and consider what you might do on the dyno with that configuration if you used a high power leaf blower to send a 65 mph wind directly up the inlet tube to the air box. This would simulate the HP you'd get for a drag race, or just accelerating onto the freeway to pass a Dodge.
At 65 mph you'll be PUSHING 858 CFM of cooler fresh air into your turbo inlet rather than making your turbo do the workload of PULLING the hotter under the hood air in there! You'd be generating about a 2" H20 RAM air pressure to help overcome the restriction of the filter element, and recoup at least some of that lost HP. If you check the Donaldson site, they advertise RAM air scoops that they claim are good for 3" to 5" H20 of boost RAM air at 65 mph. To me they look pretty ugly, but they claim to work better than the Genedad mod, which I'll admit is also fairly unsightly.
To do a realistic test to simulate the difference in intakes for towing, you'd have to start with an under the hood intake, and then work the truck hard enough to make its cooling fan lock up at 205F, then put it on the dyno with the hood closed, and measure the HP. Then follow that up with a fresh air intake using the leaf blower. I'm sure that kind of test will show even more that an 11 HP difference.
On my air filter data thread, I gave a link for the two high CFM, low restriction Donaldson filters that I included on the summary graph. These filters come in an air box with inlets, etc.. and it appears to me that they could be adapted for use on a PSD fairly easily.
Old Sep 6, 2007 | 01:01 AM
  #133
RAMPAGE_F350's Avatar
RAMPAGE_F350
Talk Soon!
Bill
Bill, I noticed that the largest universal Powercore filters only come in 8X8. Can custom sizes be made to order?
Old Sep 6, 2007 | 01:03 AM
  #134
RAMPAGE_F350
Duplicate post, ^#$% computer!
Old Sep 6, 2007 | 03:36 AM
  #135
Izzy351's Avatar
Izzy351
Originally Posted by ernesteugene
///SNIP///
///SNIP///
GENE!! That kind of test purposely stacks the results heavily in favor of the your setup! When moving at any kind of speed, the under-hood temps are a lot less than sitting still. How is it "realistic" to simulate moving at 65 MPH for your setup, then completely ignore it to let the heat sit there and build under the hood without movement for the other?
Unfortunately, I won't get to read your response until this evening -- I'm about to head out the door on a 7 hour round trip to Austin...
Joe
