CCV Mod
Old May 21, 2007 | 03:47 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by Suber
No problem at all! I think they must have changed material, cause the old o-rings were CRAP whereas the new ones I bought are made out of the same material that the oil galley plugs have. I think these will last a while at least until I have to clean the CCV again.
Really! the new o-rings are nice and tough! thats good to hear. I know the last time I bought some was about 2 years ago. Glad to hear they finally figured it out!
Old May 21, 2007 | 03:49 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by Neal 97 250
Cool thanks for the foresight. When you do this don't you need a check valve or one way valve?
Well a number of guys haven't used the check valve but I think I will be using one. I just want to make sure I am not doing bad things with the pressures!
Old May 21, 2007 | 03:51 PM
Neal 97 250's Avatar
Neal 97 250
I agree. I wouldn't imagine good things can come from pressurizing the CC with exhaust fumes when you really pour it on.
Old May 21, 2007 | 05:21 PM
Suber's Avatar
Suber
Smile
I took my hose all the way to the back, 20 ft to the rear bumper, just inside the passenger side frame. It vents nicely right out the back of the truck!
Old May 21, 2007 | 05:28 PM
powerstroked162's Avatar
powerstroked162
I like the breather idea Suber. Hows it workin for ya?
Cowboy Steve
Old May 21, 2007 | 06:04 PM
Suber's Avatar
Suber
The breather works kick-***. I just drove my truck around town and checked it while it was running and there is a nice little flow coming out the breather filter. When I stop the motor there is a little bit of exhaust that comes out of the breather but not too much.
If I was able to post pics on here I would show you the finished product. It really is a very nice fit to the end of the 5/8 hose.
Old May 21, 2007 | 06:08 PM
powerstroked162
Very nice!
Cowboy Steve
Old May 21, 2007 | 06:10 PM
Suber's Avatar
Suber
Here is the breather, it is about midway down the page. They have other colors than just yellow, I found a Blue one of course!
http://www.swapmeetsupply.com/SearchResults.asp?Cat=36
Its only about 2 1/2 inches long, and about 2 inches wide. If you take out that plug flange with the hose clamp on it, your 5/8 heater hose will bury all the way into the opening with a nice snug fit.
Old May 21, 2007 | 06:58 PM
Cuda_jim's Avatar
Cuda_jim
This is the kit I use for CCV mad. I've done 3 trucks and noticed a big difference on a highly modded 2000. You only need 1 instead of 2 like above.
I use these on all gasers I build and have seen as much as 20HP gains. Not sure about diesels.
The angel is critical, I use a vaccum gage and tap the welded-in piece to fine tune for the maximum vacuum.
Here's a link to one of my previous posts on this subject:
https://www.ford-trucks.com/forums/5...ccv-flack.html
Old May 21, 2007 | 07:00 PM
Suber's Avatar
Suber
I like that set up as well, very nice. I may tap it into the exhaust at some point too but you know how that goes.
Thank You to all that helped me with this mod!!
bkuuz1
Sep 10, 2013 08:42 AM
fishernoiter
Apr 3, 2009 12:38 PM
pushingxthexedge
Mar 12, 2008 11:00 PM
mybigredford
15
Apr 26, 2007 07:25 AM
Highmark18
Apr 22, 2006 05:06 PM
