CCV Filter and MOD
Old Sep 10, 2013 | 07:59 AM
bkuuz1's Avatar
bkuuz1
CCV Filter and MOD
Hello fellows,
Questions for you.
What have you been using to clean the dog house filter and are you able to get the hosing apart? (looked for threads but cant seem to find them)
I know there has been a CCV MOD out there for some time. For those who have done the CCV MOD, is it worth it? would you do it again? do you get drops of oil on the ground where you park your truck? (really don't want a leaker in my garage floor).
Thanks for the replays, Brice
Old Sep 10, 2013 | 08:36 AM
jeffreyt's Avatar
jeffreyt
I did it on my last truck, but I'm of the opinion that it is a pointless modification. I will not be performing that mod on Tex.
To explain the mod, there are gasses that build up in the crank case, whether it be cylinder blow by, vaporized oil, or moisture that is evaporated out of the oil, etc... The gasses will build up pressure, and if that pressure isn't allowed to vent, the pressure will be released through seals, mainly the turbo seal, causing leaks. Hence the need for a crank case vent (CCV).
Now, because these gasses aren't exactly healthy and don't exactly smell good and tend to condense back into liquid, Ford Engineers decided to route the pressure and gasses back through the engine to burn off and dilute with the exhaust. This is not an uncommon way to manage these gasses IMO. What happens over time is that those gasses will condense after the turbo (increased pressure and lower temp) and will wind up settling in the intercooler and soaking into the stock intercooler boots.
Personally I'd rather pull the intercooler once every 100k and clean it than deal with letting the gasses escape and drip on the driveway. I don't see why it's an issue, especially if you have good aftermarket IC boots.
Old Sep 10, 2013 | 08:42 AM
jeffreyt's Avatar
jeffreyt
But to answer your question, you'll have to cut off the metal clamp on the hose with a pair of dikes and replace it with a worm gear clamp. And you can use gas/diesel to clean the doghouse, or brake parts cleaner. Just make sure it's dry before you put it back on.
bad booger
20
Dec 23, 2023 09:24 AM
bakerbuilttracks
Jun 24, 2013 10:09 PM
bcg
13
Jan 18, 2009 07:58 PM
RobertJohn
13
Feb 25, 2008 11:30 PM
ernesteugene
47
Mar 12, 2007 11:07 PM
