Sponsored by: Real Truck
Wont Start
Old Jan 22, 2007 | 11:45 AM
wenglish's Avatar
wenglish
Wont Start
Have a 99 F-350 S/D, after the cold weather it doesnt want to start, heater was plugged in during the freez, went to start it the other day, it cranks but doesnt start.. any suggestions????
Old Jan 22, 2007 | 12:12 PM
99f350sd's Avatar
99f350sd
What engine?
Old Jan 22, 2007 | 12:21 PM
wenglish's Avatar
wenglish
7.3 turbo diesel
Old Jan 22, 2007 | 12:25 PM
99f350sd's Avatar
99f350sd
Well if the heater isn't working then!!!!!!!! Also vehicles aren't used to cold down there are they? All kinds of issue's, frozen water in fuel lines and tank. Wrong oil too thick, low batteries. What the temp now?
Dick
Old Jan 22, 2007 | 12:28 PM
wenglish's Avatar
wenglish
everything is correct on the truck, the weather got to the low 30's. block heater works.. just didnt want to start.... engine will crank over.......new batteries so thats not the issue...
Old Jan 22, 2007 | 12:35 PM
99f350sd's Avatar
99f350sd
Idea's maybe camshaft sensor they go like hotcakes. Other than that I would check all the things that cold will bother...
Dick
Old Jan 22, 2007 | 12:42 PM
wenglish's Avatar
wenglish
how could you check to see if its the camshaft sensor, and where exactly id it located
Old Jan 22, 2007 | 01:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
Jelled fuel?
Old Jan 22, 2007 | 01:13 PM
redford's Avatar
redford
This will explain the cam sensor - how to change it.
https://www.ford-trucks.com/article/...ke_Diesel.html
Old Jan 22, 2007 | 01:19 PM
wenglish's Avatar
wenglish
i just tried starting the truck a few minutes ago and it does the same it cranks but doesnt start.........
Old Feb 7, 2007 | 07:30 PM
lawbreaker2's Avatar
lawbreaker2
Did you get it fixed yet, Cuz my is doing the same thing, it was plug in and I started it and it ran for a few min. and quit.
alvie5757
1983 - 2012 Ranger & B-Series
Sep 28, 2014 10:02 PM
Alex from GA
Jan 27, 2014 09:40 PM
da X-man
Mar 21, 2009 04:35 PM
daerhldgs2
Sep 29, 2008 09:57 PM
Slyspy
Feb 25, 2003 04:57 PM
