starting problems
Old Sep 28, 2014 | 06:27 PM
alvie5757's Avatar
alvie5757
starting problems
Looking for help engine doesn't want to start without being primed once started ideals real good but still sometimes Boggs out on acceleration.
Old Sep 28, 2014 | 07:45 PM
jswford's Avatar
jswford
try checking the throttle position sensor.
ranger pat's Avatar
ranger pat
Veteran: Navy
I see you have a 1994, so it would be fuel injected. Which engine? When you turn on the key without engaging the starter, do you hear the electric fuel pump run? When was the last time you changed the fuel filter? Do you know how to check the fuel pressure at at the fuel rail? Have you had the codes pulled from the computer?
Old Sep 28, 2014 | 10:02 PM
alvie5757's Avatar
alvie5757
The engine is a 94 3.0. The fuel pump is running and I've bleed the fuel rail there was air in the line where I had repaired a gas line the field mice had ate it had been sitting for 2 years I don't have a pressure gage but while running the pressure is strong on the rail engine off key on not much, I've also have an issues with an after market anti theft that's has me wondering if it has the fuel shut down.
bdfesq
13
Jul 9, 2024 08:47 PM
JTM325
Jun 26, 2014 02:25 PM
nchoffar
2009 - 2014 F150
Jul 1, 2013 12:03 AM
Brickster68
Apr 10, 2013 03:57 PM
F Truck08
Aug 29, 2011 04:33 AM
