Will the plane fly?
Old Jan 4, 2007 | 04:55 PM
  #61
stu37d's Avatar
stu37d
Government Teat-sucker
Originally Posted by Greywolf
Well, let's see here.
If a Hovercraft is on a river, and the current picks up speed...
Aaw, skitch it!
This may be the best example yet.
Old Jan 4, 2007 | 04:57 PM
  #62
Greywolf's Avatar
Greywolf
Let's try this then -
The airplane is on a sheet of ice (such as a glacier) that is sliding forward ever faster.
Now, assuming the propellers are turning (OR the jet engines burning) what happens?
Old Jan 4, 2007 | 05:00 PM
  #63
catalinagoose's Avatar
catalinagoose
Man I had to think about that after posting a wrong answer on the first page. The plane will fly because the conveyer has no effect on the atmospheric conditions that the airplane is actually operating in.
Old Jan 4, 2007 | 05:04 PM
  #64
Greywolf's Avatar
Greywolf
I still like the inclusion of the idea that the conveyor may exceed it's rated speed and self-destruct. Thus ending the conversation, unless the plane can take off on top of the remains.
Blowing the tires might also put an end to it, but if the plane is moving at 120mph, the conveyor will run at 240mph - the tires might just handle it.
A 150% factor is often used as a safety cushion.
  #65
Chugalug's Avatar
Chugalug
Originally Posted by DOHCmarauder
See now you're just closing your mind...........your hand IS the prop/jet.
The plane will move forward because the propulsion is not coming from the wheels............I think you may be the last one not to get it....but I have confidence you'll grasp it in the next couple pages...
I will admit I am not the sharpest knife in the drawer but my mind isn't closed.
I am however hard headed.
This was brought up when I was in Tech school learning to work on aircraft and that was 44 years ago.
Someone ask that very same hypothetical question. After a couple of days of exter studying so we could discuss this in class the instructors and pilots got their heads togeather and decided there was no way this priticular plane would take off. Maybe my mind is closed after all. I still don't think it will fly.
Old Jan 4, 2007 | 05:06 PM
  #66
OSin86's Avatar
OSin86
If the plane is moving @ 120mph the conyer will be moving @ 120mph making the wheels turn @ 240mph.
Holy crap!!! You mean to tell me that a room full of pro's didn't get it???
Old Jan 4, 2007 | 05:07 PM
  #67
Greywolf's Avatar
Greywolf
Probably because back then they didn't have moly grease, the wheel bearings would fry, the plane have it's gear ripped out behind it, and be slung all over the desert or wherever...
I don't think that's a factor anymore.
Oh good point... (I neglected to add: "In Relation to the Aircraft". Sorry about that.)
Old Jan 4, 2007 | 05:12 PM
  #68
Greywolf's Avatar
Greywolf
Now here is a thought:
Is the speed in relation to actual position, or position over the conveyor itself?
If it is in relation to the position on the conveyor strip - then any "REAL" forward movement at all must increase the conveyors speed geometrically....
I wonder how fast a conveyor can go?
But it's all theoretical.
Old Jan 4, 2007 | 05:13 PM
  #69
Chugalug's Avatar
Chugalug
Greywolf,
Do you live anywhere near Smyrna?
I was stationed at Sewart AFB for a while before going to SEA.
Sewart is just an airport now the base was closed about 1970.
Old Jan 4, 2007 | 05:15 PM
  #70
Greywolf's Avatar
Greywolf
I live a stones throw from Memphis Tennessee, just north of it.
Old Jan 4, 2007 | 05:18 PM
  #71
Chugalug's Avatar
Chugalug
Smyrna is between Nashville and Murfesborro on highway 41.
Old Jan 4, 2007 | 06:10 PM
  #72
andym's Avatar
andym
That is exactly where it comes from. But "I" can't tell you that. The belt is turning the wheels in the reverse direction keeping the plane from gaining any foreward speed. The belt matches the speed of the wheels.
I typed this real slow so you might understand it.
Try this: Go to the airport where they have those moving sidewalks. Take a matchbox car with you. Put the matchbox car down on the conveyor belt and push the car forward and backwards with your hand. Notice how the conveyor belt has ZERO impact on the movement of the car?
Old Jan 4, 2007 | 06:11 PM
  #73
Greywolf's Avatar
Greywolf
HEY!
Be nice.
In a thousand years people will shake their heads at our ignorance anyway...
(Quite possibly in only fifty)
Old Jan 4, 2007 | 06:20 PM
  #74
andym's Avatar
andym
Fixed. Sorry to anyone who read that.
I think the people who don't "get" this have a hard time understanding the difference between propulsion being applied to the ground and propulsion being applied to the air around the vehicle.
Expanding on the hovercraft example, think about these two examples:
1 - You have a boat with a traditional propeller. The propeller spins, and the boat moves. Let's say the boat is moving upstream at 20 mph, against a current of 5 mph. In a perfect world with no friction between the hull and the water, the net speed is 15 mph. If we increase the current to 20 mph, the boat comes to a standstill. The prop is still moving, but the boat isn't. This is what people who don't get it think what is happening to the plane.
2 - Instead of a boat, consider a hovercraft under the same circumstances. Now, the current speed doesn't affect the boat. 5mph current, 20mph current, 100 mph current, the boat still moves upstream at 20 mph.
Ask yourself why the speed of the current affects the boat and not the hovercraft - now apply it to the plane vs. the car.
If you were to put a car on the conveyor belt next to the plane, you could use the analogy that the plane is to the hovercraft as the car is to the boat.
Old Jan 4, 2007 | 06:40 PM
  #75
BEECHBM69's Avatar
BEECHBM69
This has been the best laugh I've had in a good long while. I can't wait until some of our imbibing bretherin get involved in this a little later in the evening.
Why don't we add a wind tunnel to the mix just for fun?
Dan
