A way for people to see this is get on a treadmill and run or walk at a specific speed and then take a bigger step or stride. You will move closer to the front of the treadmill.
I'm glad you got it............but it's not because of the above reason.
Think of the forces involved. The engines are at full throttle, so they will apply force to the plane in the forward direction. In order for the plane not to fly, there would have to be an equal force in the opposite direction. Where does this force come from? (Don't tell me it comes from the conveyer belt.)
That is exactly where it comes from. But "I" can't tell you that.
The belt is turning the wheels in the reverse direction keeping the plane from gaining any foreward speed. The belt matches the speed of the wheels.
I typed this real slow so you might understand it.
__________________
Whom were you typing this to?
If the belt is stagnant and has no force on it; when the plane starts its T/O roll, the belt will never match the speed of the plane as the plane is accelerating faster than the belt can accelerate due to the thrust of the engines. The belt is always trying to catch-up
If you think of a boat on the water it is like the same thing. The water is a viscous media that is always moving. Once power has been applied to the prop the boat will move forward, even though the water is still viscous. It is all relative to the speed of the boat.
I would like to see the sniping at people’s intelligence to stop. IMHO
(I have not read the rest of the answers, and don't remember if I saw this before)
Since aircraft wheels are free-running, and the engines act against the surrounding air, the airplane will gather speed against the air around it and fly.
ASSUMING THE FOLLOWING DOES NOT TAKE PLACE:
The conveyor will attempt to continue to compensate for the aircrafts forward movement, will eventually be unable to, and the chances are pretty good that the conveyor, the aircraft tires, or BOTH will be destroyed.
Sigh............another correct answer but for the wrong reasons.
Try the toy car on the treadmill trick.............doesn't matter how fast the treadmill goes, you will be able to push the car forward.
Cupie dolls will be awarded for all correct or incorrect answers. Please forward twenty dollars shipping and handling with a self addressed postage paid FEDEX box to the "Greywolf Fund for Making Greywolf Fat and Happy"...
Different scenero altogeather. You are the outside force in this.
Put a propeller on the car and see if it will fly.
See now you're just closing your mind...........your hand IS the prop/jet.
The plane will move forward because the propulsion is not coming from the wheels............I think you may be the last one not to get it....but I have confidence you'll grasp it in the next couple pages...
Sounds like maybe you SHOULD go to A&M to study physics (and common sense).
Not everyone can wrap their heads around this but when you realize the conveyor has nothing to do with slowing the plane down you might want to retract the statement above.
Great example because the toy car is not being driven by it's wheels just like the plane. The plane uses surrounding air to go forward, the toy uses your hand. Both are non wheel and ground related.
