Unknown FE ??
Old Oct 18, 2006 | 05:32 AM
  #61
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Only In My Dreams! I could be so fu*kin Lucky!! *****, and I have been a good boy??
RJ
Old Oct 18, 2006 | 08:54 AM
  #62
stryder's Avatar
stryder
If I had kept the $10 from every bet I made with someone claiming to have a 427 that turned out to be a 390, I could afford one of those cool all aluminum cammers from Dove.
Seriously thou, we need some casting numbers. Head #s located between between the exhaust runners on the top side of the heads. Intake #s on one of the front runners. Block #s (if it has any) are on the front passenger side. Date code is under the oil filter mount on the oil pan rail. We need numbers pics of the crossbolts would be a plus.
We're not doubting you, just a little skeptical...thats all.
Old Oct 18, 2006 | 08:56 AM
  #63
krewat's Avatar
krewat
FTE Leadership Emeritus
Keep the cursing down. The rule is, let the language filter kill it, DO NOT avoid the language filter on purpose.
thanks
Old Oct 18, 2006 | 09:04 AM
  #64
Redmanbob's Avatar
Redmanbob
guess I got the ball rolling with the lucky mf thing sorry about that...
Old Oct 18, 2006 | 09:27 AM
  #65
krewat's Avatar
krewat
No biggee... I just don't want an admin to come down here and trash the entire thread because he didn't want to edit a bunch of posts
Believe it or not, the rules say that it's OK to let the language filter catch the profanity and clean it up. But masking the words is not allowed.
So, say ****, damn, ****, whatever As long as the language filter catches it
Old Oct 18, 2006 | 11:20 AM
  #66
Madathlon's Avatar
Madathlon
ok guys , Here are the casting numbers for the head.. C8AE-H
And A pic...
So what is it???
Old Oct 18, 2006 | 11:45 AM
  #67
stryder's Avatar
stryder
Well, its starting to look more like a warmed up 410 w/ a block that's been crossbolted. The C8AE-H heads are plain jane 360/390 heads IIRC. Any casting nubmers on the block? What about the intake?
Old Oct 18, 2006 | 11:48 AM
  #68
Madathlon's Avatar
Madathlon
ok.. 410.. Im still happy with it... I really dont know what all the hoopla is about a 427.. But at 410 its still kicking ***
Old Oct 18, 2006 | 11:49 AM
  #69
krewat's Avatar
krewat
Yup C8AE-H heads are just plain-jane, but I have a pair in my garage that are FAR from plain-jane CJ exhaust valves and lots of porting.
If I'm not mistaken, stock CJ heads flow less than a set of C8AE/D2TE's that are ported with larger valves.
Old Oct 18, 2006 | 11:52 AM
  #70
Madathlon's Avatar
Madathlon
Like I said. I dont know.. this is the 1FE I have delt with.. And im happy with it so far..
Old Oct 18, 2006 | 11:55 AM
  #71
stryder's Avatar
stryder
Yep...nothing wrong with a 410! Its still an FE and FEs are king at torque!
Old Oct 18, 2006 | 11:57 AM
  #72
Madathlon's Avatar
Madathlon
And 410 is only a guess.. Who know what the bore is at.. It could be less or more.. but it runs great.. And Im happy with it
Old Oct 18, 2006 | 12:07 PM
  #73
stryder's Avatar
stryder
Can pretty much guess the bore is 4.05...maybe 4.08 with a 0.030 overbore. Stroke is most likely a 3.98 428 crank. Like mentioned, its only a guess. If you ever have one of the heads off, post back the bore. Turning a 390 into a 410 is like turning an apple into an orange. Both are great, but the orange is always sweeter! Wouldn't have it any other way.
Old Oct 18, 2006 | 12:45 PM
  #74
rusty70f100's Avatar
rusty70f100
Yep plain old C8AE-H heads. Still very good units. Like I said before, there is not a bad FE head.
Really, the bore could be anything at this point. With the number of blocks that were in that barn where he got the truck, it's impossible to say what it has. All we know now is it has standard heads.
Old Oct 18, 2006 | 08:10 PM
  #75
baddad457's Avatar
baddad457
Even with C8AE-H heads it could still be a marine or industrial 427. Look at the blocks core plugs. If they're screw in plugs instead of pressed in, that's a dead give-a-way for a 427 block, in addition to the cross bolts (3 per side). Might even be a 454 stroker with a 410/428 crank.
