dash pad
Old Mar 25, 2001 | 10:42 AM
holl's Avatar
holl
dash pad
How do you remove the dash pad on on a 1977 F 150. I bought a replacement but can't see how to take the old one off.
Old Mar 25, 2001 | 11:09 AM
sparky's Avatar
sparky
dash pad
There are about 10 or 12 studs attached to the dashpad that stick down thru the metal frame that the dashpad rests on. You have to remove the nuts from these studs and the pad lifts off. Easy enough said but the nuts are a little hard to get at. I removed the speedometer panel and glovebox for access.
Sparky
Old Mar 25, 2001 | 11:30 AM
glenn 79's Avatar
glenn 79
dash pad
Sparky hit the nail on the head. Try to remove the gauge cluster
and the glove box. Some are hard to get at. I would wear a long
sleeve shirt because the dash has some sharp edges.
Glenn
Old Mar 25, 2001 | 01:03 PM
ford4604x4's Avatar
ford4604x4
dash pad
they told ya rite way but there are studs that point toward the front of truck.in other words as you are facing the dash.the lip that hangs down in the face of the dash has studs sticking out that face the fire wall of the truck and the very middle of the dash that has the piece between the insterments and the glove box has a stud also.
https://www.ford-trucks.com/dcforum/User_files/3a98299615e4afbe.gif
Old Mar 25, 2001 | 02:26 PM
fastford's Avatar
fastford
dash pad
78f250_rls
16
Nov 11, 2024 12:57 PM
Ripcity
Sep 30, 2013 07:36 PM
sweetlou1
Mar 6, 2013 10:53 AM
mustanginca
1983 - 2012 Ranger & B-Series
May 17, 2007 11:14 AM
bretts3504x4
Aug 28, 2006 05:21 PM
