Dash pad replacement tips
Old Aug 26, 2006 | 09:17 PM
bretts3504x4's Avatar
bretts3504x4
I did not see any tips or tricks posted for a dash pad replacement on a early '77. How hard is it??
Thanks
Old Aug 26, 2006 | 09:23 PM
78f-150Supercab's Avatar
78f-150Supercab
Are you looking for advice on removing the dash pad or finding a replacement?
Removing the dash pad is pretty easy. There are eight screws/nuts holding it on. To get to them, you need to pull out the instrument cluster and glovebox. I've outlined how to do it in some other threads and I know other people have explained it several times before. Do a quick search in this forum for "remove dash pad" or something and you should find a couple good threads explaining where all the screws are.
Old Aug 26, 2006 | 09:30 PM
Ruo1630's Avatar
Ruo1630
Super easy. Pull the gauge cluster and dash liner out, and reach up. You will feel the studs poking through with nuts on 'em. Just dont forget the one in front in the middle, facing the firewall. You can do it in about 45 minutes on your first try. If you've never pulled a speedo cable before, then you should squeeze the plastic retainer on the end until it's an oval, and then pull it out. Also there are 2 retainers on the elec. connector, 1 at each end. Just squeeze and pull that also. For inspiration I recommend Budweiser Select. Hope this helps.
Old Aug 26, 2006 | 09:41 PM
bretts3504x4
Both of these replies are extremely helpful. I did some thread searches but did not use the correct words I guess since i could not find it. Thanks for the replies as I am new to this truck.
Old Aug 27, 2006 | 12:13 AM
George Frasier's Avatar
George Frasier
Another option is a "Dash cover" that slips over the dash pad - thin and usually fits like a form-fit. They come in several colors and also come in vinyl or carpet-like to match your floor. Several companies offer each of the above.
Old Aug 27, 2006 | 07:10 AM
cooky's Avatar
cooky
I just put a cover on my dash.(1979 F250.Fit real good.I had to paint mine though since you can't seem to find the ford green any where.
Old Aug 27, 2006 | 09:02 PM
bretts3504x4
George and Cookie, does the cover look as good as they make it sound? My interior is black so color is not a problem. $79 sure beats $299 any day.
Old Aug 27, 2006 | 09:09 PM
78f-150Supercab
Have you checked any junkyards? I've seen one every once and a while in good shape. If you're lucky you might be able to find one without cracks that you just have to clean or maybe paint.
Old Aug 27, 2006 | 09:29 PM
bretts3504x4
I have a local yard that has three trucks that I know of. One truck is a '73 and one is a '79 (I don't know about the third yet) but I am still learning the years that fit on different pieces and trying to compare it with parts catologues. Any advice?
Old Aug 27, 2006 | 10:27 PM
78f-150Supercab
The dash pad is the same from 73-79. Most parts for those years are interchangable.
Old Aug 28, 2006 | 05:21 PM
George Frasier
Just a thought - I have used model car spray paint for several things auto. 1. It's made for plastic and there are a lot of colors and shades of each. 2. It works on "plastic" windows for tinting. There is a "Window Tint" (charcoal) for model cars that CAN be used on most plastics. All the above - Dust-coat till the desired tint or darkness happens. For dark GLASS windows, there is a window film ( in diff shades ) that can be applied. Normal soap/water prep.
shortwide
15
Aug 30, 2014 02:04 PM
hazer
May 30, 2013 11:19 PM
Ol' Blu
Georgia Chapter
Dec 11, 2005 09:25 PM
HardFordCore
Nov 7, 2003 03:02 PM
JEGuzzardi
Jul 14, 2003 01:47 AM
