timing specs for a 1970 429/460???
Im runnin mine at 14 now with regular gas and I am getting a little pinging on upgrades. Plus it cranks real hard and slow when hot so I need to set it back a little. My truck is a 75 but my block is a 77. I think i'll try it at 11 and see how that feels. It's a recent overhaul with only 1000 miles on it.
The definition of "stock 460" is too vague. Ford changed the specs on the 460 in the early 70s with taller decks, larger combustion chambers which lowered the static C.R. from 11:1 down to +/- 8:1.
The OP asked specifically about a 1970 429/460 which has the 10.300" deck and +/- 75 cc comb. chambers. There's no way I can run my 1970 429 with 11:1 advertised C.R. at 14 deg even on premium. I run it at 4 deg because that's about as much as I can get away with. I've tried it as high as 10 deg and it simply won't tolerate that much initial timing.
I run 20* inital and modified the distributor to around 6* to 8* ... total 32 to 36.
Will know better after installing 0* timing set and a timing tape. I tow a 12 to 14,000 lbs trailer. When I got the truck had to run 92/93 octane (had 44* total adv) now down to 89 maybe less with some more tweeks. Also started at 6 mpg hiway now up to 12 havent had a good hiway test run before putting away for the winter.
'83 F250; Original 460; 108,000 miles; 15deg BTDC
I've experimented with a WIDE range of timing advances, from 30 BTDC to the stock 6 BTDC. Here are my findings (all numbers are BTDC):
30 - Hard to start, pings a lot even with premium fuel
25 - Not as hard to start, not as much pinging, almost liveable, good power & mpg
15 - No hard starting, no pinging on premium, excellent power, best mpg
6 - Easy starting, no pinging with any gas, gutless, 2mpg less than 15BTDC
I keep it at 15BTDC now, all the time. Even on regular fuel, it very seldom pings.
Keep in mind that this vintage 460 has a low compression ratio, and this particular truck has 4.10 gears, so the engine never lugs or struggles.
Oh, I almost forgot! At the factory 6BTDC, the engine runs hotter (as observed on the temp gauge) than at 15BTDC under all conditions. At 30, it pinged so much I didn't leave it at that setting long enough to check mileage, and I didn't test power, either.
I'm certainly no expert on this kind of stuff, but I learned a lot by just trying different ignition timing settings and observing fuel economy, coolant temps, seat-of-the-pants dyno readings and listening for pinging.
huntinfool87
02-22-2017 09:50 PM
429 FORD POWER
07-09-2009 11:44 PM
Greg Blackmon
03-02-2008 03:47 PM
illuminance72
10-01-2004 02:53 PM
