360 vs 429
Old Feb 16, 2008 | 09:14 AM
Greg Blackmon's Avatar
Greg Blackmon
360 vs 429
Ihave a 1968 f100 I just restored that has a360 bored in it . Ifound a 429 with DOVE A on the block an the heads have DOVE C ON THEM . Is this a good engine to rebuild and what trouble is it to put this in my truck? thank any help. Greg
Old Feb 16, 2008 | 11:37 AM
85e150's Avatar
85e150
Different engine family. Diff mounts, different trans, linkage, accessory drives, exhaust, possibly need diff radiator.
429 is a much better engine, but it's not a drop in swap. Then you'll alway wish you'd gotten a 460 for your trouble...
Old Feb 18, 2008 | 01:41 PM
385seriesHemi's Avatar
385seriesHemi
From what I hear most 360s get the same mpg w/ truck loaded full or not so it would be a good work horse in my opinion. The 429 & 460s were designed for replacing the FE engines in larger cars and soon trucks after 1972-'73 I believe. I would go with the 429 myself but modding an FE is just as easy since all the FE parts interchange with one another so you have a large variety to choose in parts.
Old Feb 20, 2008 | 06:00 PM
65f100_352's Avatar
65f100_352
You can also make a 360 into a 390 very easily. Just a crank, rods and pistons to make it a 390.
Old Feb 22, 2008 | 08:20 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Why go 390 when he could go 428, then he'd only be a cubic inch off. That 429 was a good find though, those are a decent set of heads on it. But there are odds and end's in the swap that eat up money, mostly motor mounts (they can be made urself though) and a bellhousing.
Old Feb 22, 2008 | 09:35 PM
monsterbaby's Avatar
monsterbaby
because you can't bore a 360/390 block far enough to make a 428 out of it. But you can stroke it with a 428 crank and make it a 410
Old Feb 22, 2008 | 09:43 PM
Redneck-Cowboy
Oops, my bad, I knew better then that, thanks for catchin that though, duhhh
Old Mar 1, 2008 | 07:40 AM
Greg Blackmon
429 heads
I took my heads to a machine shop to have them check. The guy told me that theywould have to be cut .030 to clean up. Also have to cut intake side to make intake fit. If I went with 10 to 1 comp. would this be to much for pump gas , or would I have to lower comp. pistons ? He said the dove c heads are closed chamber heads an they were worth fixing. What do you guys thank ? Thanks Greg
Old Mar 2, 2008 | 01:02 AM
Redneck-Cowboy
I think he's right, the heads are worth it, as for pump gas you'll have to run 92/93 octane to keep it from pinging, but you should be able to still squeeze by on premium.
Old Mar 2, 2008 | 03:47 PM
385seriesHemi
Remember you have many different headgasket thicknesses around to play with your compression too.
72bigredflatbed
51
Nov 30, 2018 11:42 PM
huntinfool87
Feb 22, 2017 09:50 PM
shadow_almanza
Mar 1, 2010 07:55 PM
icuhatn99
Jan 27, 2006 10:29 PM
ranger429
Jun 6, 2003 02:59 PM
