Next Tuttle Time?
Old Oct 12, 2005 | 01:19 PM
  #61
Flip4ford's Avatar
Flip4ford
Sounds like a MOD / Fix Party to me???Hey husker what is the rain situation like? Just wondering if we are in for a giant mud hole or not?
Old Oct 12, 2005 | 07:58 PM
  #62
husker's Avatar
husker
We didn't get all that much rain here in Manhattan, so unless we get a bunch between now and the 22nd things should be good to go. I'm trying to talk the son in law into bringing his Scout, but he is dragging his feet. And thats after he fixed the holes in the floor of the truck. hehe.
Old Oct 12, 2005 | 09:34 PM
  #63
HappyJack's Avatar
HappyJack
So Rollie, did you get the mapping software to work with your GPS?
Old Oct 12, 2005 | 09:39 PM
  #64
97Centurion's Avatar
97Centurion
Rub my Belly
I'm not Rollie but I can download stuff from the GPS to Delorme but not upload anything to the GPS.
Old Oct 12, 2005 | 10:10 PM
  #65
fordborn's Avatar
fordborn
Yes Jack I got it to work. I had to add the way points from the delorme then put them to the GPS then upload back to the delorme. A little work but was able to make it work.
Also found another map of Tuttle that shows a few more things then I have seen yet. http://www.flatlandersjeepclub.com/ORV/ORV.htm
Tony, I guess the software worked for you? Did you order the other software?
Old Oct 12, 2005 | 10:11 PM
  #66
HappyJack's Avatar
HappyJack
Have you tried the help section? Delorme should tell you how to do it.
Old Oct 12, 2005 | 10:12 PM
  #67
97Centurion
Rub my Belly
Correction.. Delorme will not reconize my GPS but Rollie did say that he was able to load the tuttle routes to his GPS or something like that. I should shut up. lol I ended up getting Mapsend Topo for mine.
I'm double checking help now.
Old Oct 12, 2005 | 10:14 PM
  #68
fordborn's Avatar
fordborn
Tony, you have to go to GPS on the bottom, then exchange button, then device setup, then device. Scroll down to Magellan. Also make sure your unit is set on 4800 baud or it won't find it.
Old Oct 12, 2005 | 10:16 PM
  #69
fordborn's Avatar
fordborn
You must have it set on 4800 baud, like I said in other post. Had the same trouble because mine was set on higher speed. Once changed it to 4800 it was fine.
Is that the TOPO I sent or did you get the 3D
Old Oct 12, 2005 | 10:17 PM
  #70
97Centurion
Rub my Belly
Ok the directions say .....You have to go to GPS on the bottom, then exchange button, then device setup, then device. Scroll down to Magellan. Also make sure your unit is set on 4800 baud or it won't find it.
Guess I'll try that. lol
Old Oct 12, 2005 | 10:20 PM
  #71
97Centurion
Rub my Belly
I ended up getting the 3D.
Old Oct 12, 2005 | 10:22 PM
  #72
HappyJack's Avatar
HappyJack
Ok, just wanted to make sure Tony can find the pipe and his mud holes.
Old Oct 12, 2005 | 10:30 PM
  #73
97Centurion
Rub my Belly
Found the problem! NMEA setting was wrong. I kinda like the DeLorme better than the MapSend program.
Old Oct 12, 2005 | 10:31 PM
  #74
fordborn's Avatar
fordborn
I do to but I gave my only copy to didn't get it on the laptop.
Old Oct 12, 2005 | 10:37 PM
  #75
HappyJack's Avatar
HappyJack
And they are pretty cheap also. The 4.0 is a lot better for what I do in Colorado and Utah and they really went down in price since the 5.0 has been out. Most folks I know have gone back to the 4.0 after using the 5.0 for a while. Just do a search for Delorme and you will find a bunch of places that are selling brand new for a few $$$'s. Or they are on e-bay also.
