Next Tuttle Time?
Old Sep 24, 2005 | 10:04 PM
97Centurion's Avatar
97Centurion
Rub my Belly
What bracket you looking for?
Old Sep 24, 2005 | 10:07 PM
Flip4ford's Avatar
Flip4ford
Originally Posted by husker
Hey Flip, how are the arms? Do you look like Popeye yet? LOL
Just waiting on the anchor tatoos to dry ---- :-) May have found a ps pump and gear :-) going to do a little research before I buy them.
Old Sep 24, 2005 | 10:09 PM
74 bronco's Avatar
74 bronco
Flip I hope it works out.
Old Sep 24, 2005 | 10:13 PM
husker's Avatar
husker
Hey, good luck on the PS. And I had forgotten about the anchor tatoos.
Old Sep 24, 2005 | 10:41 PM
fordborn's Avatar
fordborn
Your right Clint, they will never be done, but just maybe it will be running.
Originally Posted by 74 bronco
But Rollie they are never done because you will change your mind then change something else.
Old Sep 24, 2005 | 10:51 PM
HappyJack's Avatar
HappyJack
You mean they are all supposed to run?
Old Sep 24, 2005 | 11:02 PM
fordborn's Avatar
fordborn
At this point I am not sure about that. I have found though that my fuel and tires are lasting a lot longer sitting in the driveway.
Old Sep 24, 2005 | 11:05 PM
97Centurion
Rub my Belly
Old Sep 24, 2005 | 11:07 PM
fordborn's Avatar
fordborn
It's th bracket that holds the shift linkage and is bolted to the bellhouseing.
Old Sep 25, 2005 | 07:56 AM
HappyJack's Avatar
HappyJack
I can send you a picture of it if it would help!
I have the one I bought and it's not in use right now. So if you need it you can use it till you find another one.
Old Sep 25, 2005 | 08:10 AM
fordborn's Avatar
fordborn
Where did you find one? I know it is out there someplace just haven't looked in the right corner yet. Looks like time to clean the garage out again and then we will probably find the thing.
Old Sep 25, 2005 | 09:13 AM
HappyJack's Avatar
HappyJack
I posted a wanted on the other boards and a guy back east had one and the rod I also need that conected to the tranny.
This is a popular tranny for a v-8 swap and now a bunch of folks are using them when the A4LD dies in Explorers, Rangers and BII's. Rebuilt A4LD is about $1500 carry out. C-5 upgraded with the c-4 valvebody and v-8 stuff $500. And the C-5 will outlast the A4LD. Only trouble is you lose the over drive.
Many don't bother with converting the shifter and just through those parts away. Most just get an aftermarket shifter.
The junk yards I talked to won't pull a shifter either. Too much work and not enough $$$'s in return. I still need a dip stick and tube. I have an aftermarket chromemum job but Clints says it just keeps cutting the o ring when he puts it in.
Thing is this tranny was only put in some 83-84 Rangers and the 84 BII. The only other source for some parts is the 70's Mustang/Capri with the 2.8 and C-4. Just not a large pool of parts to begin with.
Old Oct 3, 2005 | 12:42 AM
  #28
97Centurion
Rub my Belly
Will since none has posted a date besides Flip, I think I'll be there on the 22nd of October also. I know Rollie was wanting to go the 15th but do to some unfortunate incidents, My BII probably won't be back together before that weekend.
Old Oct 3, 2005 | 01:05 AM
  #29
HappyJack's Avatar
HappyJack
What happened to your BII? I have parts if you need some.
Old Oct 3, 2005 | 01:09 AM
  #30
97Centurion
Rub my Belly
Thanks to someone I love and adore ... It needs a clutch. Just no time to install one for a week or so.
