1978 - 1996 Big Bronco
Power window quandary
Old Jul 17, 2005 | 06:52 PM
bmw0325's Avatar
bmw0325
I have a 90' Bronc whose driver side window will no roll up or down properly. Here's the details I have after trying to fix it:
-The motor works for both directions
-window is on track
-all screws/bolt seem to be in place and tight
-window will move up/down if you manually help it out
-gear teeth in motor don't seem to be meshing with the gear teeth for the window assembly (actually they do help some when rolling down but not at all up)
Any help/ideas would be much appreciated.
Old Jul 17, 2005 | 07:01 PM
ctch88's Avatar
ctch88
Hey, I have the same problem on the passanger side. I haven't gotten a chance to look at it yet, but I think it might be something to do with a broken weld on the bracket at the bottom of the window. I'll look at it tonight and let you know if I find my problem.
Old Jul 17, 2005 | 07:05 PM
gov2mod's Avatar
gov2mod
With all of my Fords I've fixed plenty of them. After you remove the motor, take the one screw out of the plate around the gear and remove that cover. There are three 7/16 diameter nylon bearings/pins that have disinegrated and that's the problem. You can get a gear kit from Autozone, Advance, etc., with these nylon pins and a gear but you never seem to need the gear. I just make my own on my lathe from a larger piece of nylon. I think there's a guy on Ebay that sells them as well.
Old Jul 17, 2005 | 08:28 PM
ctch88's Avatar
ctch88
There is a plug type screw sitting on the top of the motor. I thought this might be a clutch adjustment. Is that a good or bad guess. Any secret on getting that bottom screw out from the mounting plate? I have pretty skinny hands, and still can't get to the damn thing, and I don't want to have to pop out those mounting plate rivets either. Why couldnt Ford have just left a big gap in the door... hey, there's an idea...make a bigger hole, anyone got a sawsall I can borrow?
Old Jul 17, 2005 | 08:36 PM
gov2mod's Avatar
gov2mod
Don't bother with the adjustment screw, it's the nylon bearings that have broken into many little pieces, it's a very common problem. As for the screw just drill a hole (about 3/8") in the door directly over the screw and then use a 1/4" drive 5/16" socket or a 5/16" nut driver. I believe that's the size. I don't know why Ford didn't have the holes in there in the first place. I've seen a LOT of Ford doors with the holes drilled in them and have done it to most of mine as well.
Old Jul 17, 2005 | 08:39 PM
gov2mod's Avatar
gov2mod
Don't bother drilling out the aluminum rivets either. You don't need to remove the whole regulator assembly, only the motor. You can do it with the three little bolts removed and take the motor out the same hole that the window motor wire goes thru.
Old Jul 17, 2005 | 08:47 PM
ctch88's Avatar
ctch88
Good tip, I guess I get so frustrated with the one problem, that I don't think of alternate solutions. Gotta work on that, but until then, I'll keep posting my problems. Thanks gov2mod.
Old Jul 17, 2005 | 08:51 PM
gov2mod's Avatar
gov2mod
No problem, you learn from others (in this case mine!) mistakes. Years ago I drilled out the rivets on the first one I ever did and removed the whole assembly. What a pain. As soon as I got it out and looked at it I thought "What a dumb *** I am", when all I had to do was drill a couple of holes and remove the motor.
Old Jul 18, 2005 | 07:00 PM
ctch88's Avatar
ctch88
Well, my window now runs like a champ. What about you bmw0325? I found reman motors at NAPA was $57 after the core charge, but they didn't have the nylon kit, at mine anyway.
Old Jul 18, 2005 | 07:56 PM
gov2mod's Avatar
gov2mod
CTCH88, did you trade in your old motor yet? What was the core charge? You can get the nylon pins from Ebay for about $5.
Old Jul 18, 2005 | 09:31 PM
ctch88's Avatar
ctch88
Yea, too late for me. I bought the reman. motor. It was $57 after the $16 core. I'll keep ebay in mind though. I didn't have time to turn my own either, although I'd like to see a new set before even attempting that. For some reason I thought the motor was only $20 or so, and was surprised at the $57. I had replaced the rear window motor on my old bronco a few years ago, maybe thats why I don't remember so well. Oh well.
Old Jul 18, 2005 | 10:42 PM
220k-f-150's Avatar
220k-f-150
You, can buy them nylon pieces at auto places that have HELP parts. Less than $10 per window.
Old Jul 19, 2005 | 06:49 PM
bmw0325's Avatar
bmw0325
Thanks for the awsome advice. I'm glad to here the simplified proceedure too. I've actually be swamped at work and haven't had time to work on the truck. I let you guys know how it goes when I do. Thanks again for the advice.
logger1989
May 5, 2014 08:46 AM
teamlx88
Feb 2, 2014 03:34 PM
teerex
Nov 11, 2013 08:30 PM
cfauvel
1997 - 2003 F150
Aug 3, 2005 07:59 AM
clifFORD
Apr 13, 2002 11:10 AM
