Notice Any Difference?
My '06 has a few more than 5, but not all of them are "major".
59k miles on it is NICE!
- ALLIANT POWER NEW FUEL INJECTOR CONTROL MODULE, FITS 2004.5-2010 FORD 6.0 POWERSTROKE BUILD DATE ON OR AFTER 09/22/2003 4 PIN
1.0 - 2003-2010 FORD 6.0 POWERSTROKE UPDATED SOLID STEEL TURBO SUPPLY TUBE
1.0 - 2003-2006 FORD 6.0 POWERSTROKE CYLINDER HEAD, 18MM DOWELS, BUILD DATE TO 01/11/2006 ENGINE SERIAL NUMBER 6,000,000-6,723,721
2.0 - 2003-2010 6.0 FORD POWERSTROKE CYLINDER HEAD GASKET - 18MM DOWEL PIN SIZE, FITS BUILD DATES 2003-JANUARY 11TH 2006, SOLD INDIVIDUALLY
2.0 - ARP HEAD STUD KIT 2003-2010 FORD 6.0 POWERSTROKE 14MM ARP2000 MATERIAL
1.0 - 2004.5-2010 FORD 6.0 POWERSTROKE GLOW PLUG, FROM 09/22/2003 - ICP LOCATED AT FRONT OF PASSENGER SIDE VALVE COVER
8.0 - 2005-2007 6.0 DRIVER SIDE GLOW PLUG HARNESS - BUILD DATE 07/19/2004--12/18/2006
1.0 - 2004.5 & 2005-2007 6.0 PASSENGER SIDE GLOW PLUG WIRING HARNESS BUILD - DATE 01/15/04-12/18/2006
1.0 - 2003-2010 FORD 6.0 POWERSTROKE VALVE COVER GASKET SET
1.0 - 2003-2010 FORD 6.0 POWERSTROKE FUEL INJECTOR ORING KIT
1.0 - 2003-2010 FORD 6.0 POWERSTROKE ENGINE OIL COOLER
1.0 - 2003-2010 6.0/6.4 EXHAUST MANIFOLD GASKET (INDIVIDUAL)
2.0 - 50/50 ELC Coolant CAT EC-1 RATED, RED
7.0 - 2003-2010 6.0/6.4 POWERSTROKE OIL FILTER - MOTORCRAFT
1.0 - 2003-2010 FORD 6.0 POWERSTROKE FUEL FILTER KIT, INCLUDES PRIMARY AND SECONDARY WATER SEPERATOR FILTER
1.0 - REFRIGERANT R-134A (SOLD PER POUND)
2.69 - PAG 46
1.0 - 2004.5-2010 FORD 6.0 POWERSTROKE SQUARE EGR COOLER - INCLUDES GASKET KIT, BUILD DATE ON OR AFTER 09/22/2003
1.0 - 2004.5-2010 FORD 6.0 POWERSTROKE UPDATED HIGH PRESSURE OIL STANDPIPE AND DUMMY PLUG COMPLETE KIT, BUILD DATE FROM 09/22/2003 x1 KIT PER VEHICLE
1.0 - FUEL PRESSURE SPRING KIT, FITS 2003-2010 FORD 6.0 POWERSTROKE
1.0 - POWERS STEERING FLUID 1 GALLON
1.0 - Hot Shot's Secret Green Diamond Fleet 5w40 Full Synthetic CK4 Engine Oil with FR3 Nano-Technology
3.75 - 2003-2010 FORD 6.0 POWERSTROKE UPDATED TURBO DRAIN TUBE
1.0 - 2003-2007 FORD 6.0 POWERSTROKE METAL COLD SIDE INTERCOOLER TUBE, INCLUDES SILICONE HOSES ON BOTH ENDS AND 3 CLAMPS
1.0 - UNLIMITED DIESEL PERFORMANCE 2003-2007 6.0 COOLANT FILTER KIT - INCLUDES FILTER
1.0 - BULLET PROOF DIESEL 100MM BILLET WATER PUMP ASSEMBLY, FITS 2004.25-2010 FORD 6.0 POWERSTROKE, BUILD DATE 09/23/2003 AND AFTER
You only get extra power, etc when you install a tune.
One other thing to have is the blue spring upgrade on the fuel pressure regulator - helps preserve injector life to keep fuel pressure over 45 psi (hopefully you had the upgraded spring installed).
It is HIGHLY recommended to install a pressure gauge on the fuel supply also!
Did you have the heads o-ringed?
I am not sure what you were told about the outcome but it will be your same truck but more dependable if put together CORRECTLY.
I am curious about your cylinder heads and where they were obtained new or if your were original machined, were they o-ringed?
Sensors are not cheap (ICP,IPR) so if they're not broken why replace them?
What was wrong with the FICM since it is new and what condition are your injectors in? A bad FICM ruins injectors so were they replaced or deemed ok?
There’s also a risk when handling any 20 year old connector or wire bundle.
I maintain my own vehicle on most repairs, but found myself an absolute clutz with the 6.0.
Example was losing orings on the ground with the blue spring upgrade. Then installing it wrong so it leaks.
So, if you have a good track record with diesel repairs and you are not missing a rent payment or food, or going deep on debt could be a good choice.
IMO there are only two HPOP's to consider - DieselSite and CNCFab. I know the HPOP isn't cheap, but if the engine is being worked on that deep anyway, it sounds like the right time.
IMO, the wiring issues that the 5.0L engine suffered from came from several sources:
- rubs and stress from routing issues
- excessive engine heat
The IPR is a toss up. With so few miles on it, I would tend to say just keep it.
Has the screen under the oil cooler been inspected or replaced? That is another thing to consider (there is an upgrade to that also).
Glad the heads are o-ringed!!!
It would be good to know what shop is doing the work!!
Lastly, I believe that upgrading the original FICMs (at CircuitBoardMedics or FICMRepair.com) will give you better reliability than buying a new one (and it is cheaper). You went another direction and I hope it works well for you. What happened to the original FICM, did you keep it?
I will put another plug in for the installation of a fuel pressure gauge - EVERYONE needs it!
Hopefully the EGR cooler was from BulletProofDiesel!!! It is the ONLY one I would trust for 2004.5+.
MAKE SURE to charge the batteries and then individually load test them. These engines need good power supply!!! Lots of people upgrade alternators also. Something to consider when you get enough funds.
