'97 Expy EB - Driver's side window problem
Old Nov 10, 2013 | 12:30 PM
teerex's Avatar
teerex
Hello All:
The driver's side window on my '97 Expy has developed a new issue. When I hit the Auto window down switch, it goes all the way down. Then when I try to bring it back up, it seems to get stuck momentarily and then with a loud thunk the motor kicks in and pulls the window back up. I am suspecting that the window is going so far down that the teeth on the window arm are getting disengaged from the motor's gear. If I don't use the Auto down and carefully bring down the window with the switch without bottoming it out, it will go up just fine.
Is there a way for me to limit the lowest position that the window will go to when I hit Auto down ? If not, I can live without the Auto down feature so how do I disable it ? I have opened the driver's side door panel and have access to the window switches, window motor (which I replaced last year) and the scissor mechanism for raising/lowering the window.
Thanks for any advice
Old Nov 10, 2013 | 01:39 PM
alloro's Avatar
alloro
pull the panel and see if the stop broke.
Old Nov 10, 2013 | 03:36 PM
teerex's Avatar
teerex
Thanks for your response, Alloro. I'm not sure what I should be looking for though. I have the panel open and I've put my hand inside the door cavity to feel around the window track but didn't feel anything broken off.
Cheers
Old Nov 11, 2013 | 11:29 AM
alloro's Avatar
alloro
Okay, to be a bit more specific, in the below image note the gear within the red circle where the teeth stop. That is the travel limit stop. The spot weld within the blue circle can break free and allow the gear to move enough so that the window motor rides right over the stop within the red circle.
Old Nov 11, 2013 | 08:30 PM
teerex's Avatar
teerex
Okay, to be a bit more specific, in the below image note the gear within the red circle where the teeth stop. That is the is the travel limit stop. The spot weld within the blue circle can break free and allow the gear to move enough so that the window motor rides right over the stop within the red circle.
Hi Alloro:
Thanks very much for clarifying exactly with the picture. I checked the arm and the weld seems to be fine. From your description, I was pretty certain that's what the problem would've been. So, I'm still not sure what was causing this.
Anyways, I used my multimeter to figure out that the brown wire on the window switch is the one that triggers the Auto down relay and I snipped it to avoid accidentally triggering the Auto down. Now, I am restricted to bringing the window down manually but I'm fine with it. Just didn't want the motor to break down because of this.
Cheers
7622RM
1983 - 2012 Ranger & B-Series
Dec 11, 2018 05:34 PM
ddixon72
Feb 23, 2011 11:32 AM
Lobo
Feb 15, 2010 11:41 AM
putter
Jan 30, 2010 04:41 PM
PsD007.3
13
Dec 8, 2009 12:07 PM
