tried zenor diode mod
Old Feb 18, 2005 | 05:29 PM
barebackjake's Avatar
barebackjake
i would try to see if you can get it scanned though to see which code it is. where did you put the diode in ?? on the map sensor or the IPS??
Old Feb 18, 2005 | 05:35 PM
jadel's Avatar
jadel
on the map sensor,i soldered the banded end into the middle wire green with brown stripe and i soldered the other end to a long wire which run to ground on the fire wall.
Old Feb 18, 2005 | 05:49 PM
barebackjake
yeah going to the map sensor is something im not familiar with. i can get a pic of where my regulator is if this weather breaks. i have the clamp mod on the IPS with a switch to control it.
Old Feb 19, 2005 | 05:36 AM
jadel's Avatar
jadel
Thanks that would be great.
Old Feb 19, 2005 | 10:52 AM
jadel's Avatar
jadel
i think the code is injection pressure over/under limit. my truck does this
I have already shimed the ipr with a bb and a screw could this be to much pressure with the 10 k mod originally i only had 30psi at the schrader valve now with it shimed i have 70-80psi if this is the problem with the check engine light and defueling then i will not have to put a boost pressure relief valve in
Old Feb 19, 2005 | 12:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You have the ZD wired in correctly....Assuming you used a 4.7v and not a 5.1 or something, your SES light is not from overboost. It's unlikely your FPR adjustment has anything to do with it. When you installed the 10K resistor in the ICP you adjusted the oil pressure.
You need to remove the 10K mod, and disconnect your batteries for a couple of hours to clear the codes, then take it out and drive it and see what happens.
Old Feb 19, 2005 | 01:38 PM
jadel's Avatar
jadel
i have a switch on the 10k mod if i just shut this off and unhook the batteries would this be ok.
Old Feb 19, 2005 | 04:15 PM
cookie88's Avatar
cookie88
FTE Emeritus
It would be better to completely remove it. That way you wold eliminate any possibility of the switch grounding out, but you could leave it in place for the first test.
jeffreyt
Oct 19, 2012 09:16 AM
AkF250HD
Aug 30, 2012 10:21 AM
AndeyHall
Nov 12, 2009 11:17 PM
my79f
15
Jan 2, 2006 09:38 AM
Killer
Modular V8 (4.6L, 5.4L)
17
Aug 4, 2003 02:51 PM
