Fog Light Mod
Old Nov 12, 2009 | 03:41 PM
AndeyHall's Avatar
AndeyHall
Fog Light Mod
I have an '03 that I was trying to do the fog light mod on. I did it on my '04 and it worked fine. On this truck, when I ground the wire and then flip the brights on, it blows the bright light fuse. Why would this be?
Old Nov 12, 2009 | 05:24 PM
jsimon724's Avatar
jsimon724
Are you grounding the right end of the wire after you cut it? Not trying to be a smartass, just asking. If you haven't done it in a while, it's easy to make a simple mistake. IIRC, you ground the wire coming from the harness plug and just cap the other wire. See, if I was gonna do it, I'd have to go back and look for the instructions again, cause I'm not 100% sure.
Old Nov 12, 2009 | 11:17 PM
AndeyHall's Avatar
AndeyHall
I'll have to see because I may have done it backwards now that you mention it.
troverman
Oct 3, 2018 09:01 PM
williamwilliam
Sep 11, 2011 06:02 AM
aquaman
6.4L Power Stroke Diesel
Nov 11, 2009 12:57 AM
AlaskaJeff
Sep 28, 2009 09:33 AM
daimon1054
Aug 21, 2002 09:22 PM
