I just called the diesel tech where I get my truck serviced. The last flash I had was the Dec 03 3U7A-12A650-FTC. Mine is an early 03. They say there is a new flash available but not for all 6.0s. Some trucks it will update and some not. The diesel tech couldn't tell me which ones. I asked what it is supposed to fix. He said he thought it was supposed to fix some surge or hesitation problems while towing but wasn't sure.
Katoum's posts and a message from Bob got me looking into this.
Does anybody else have any more info on this? PSD 60L Fx4 how about you?
I had my truck reflash on 11/27/04 it was a new flash only a week old . My truck had rough idle, white smoke on start ups ,idle surges and some bucking. It made my truck perfect I can't stop driving it starts easier runs smother but does have a little more noise but I'am ok with that. My truck is a 03.
I just got the latest 03 flash 3U7A-12A650-FTE for my 03. It is supposed to fix hesitation at low rpm and tow/haul mode improvements.
So far it seems to run like it did when I bought it less the pilot injection. Acceleration is good. It shoves you back in the seat when hitting the on ramp.
Too early to tell on the mileage.
I haven't tried reloading the Predator yet. I want to see what the mileage does first.
I can't confirm it but I read somewhere that there is a recent flash out for the 04. Call your service department and ask to speak directly to the diesel tech.
My 04/04 truck was just flashed with 4U7A-12A650-BGC. Don't know if this is old or new, but that is what the sticker says in the engine compartment. Seems to have less turbo spool up time from a dead stop.
I might post something when I find out more about this flash...so far, since it was posted, I haven't even been to work, so I don't know anything about it yet
SBV, keep us posted on how it does...
Overall, does it seem to be an improvement?
It seems to be a definite improvement. Remember, I bought mine in August 03. It had pilot injection and would push you back into the seat getting on the on ramp. I had a very minor problem with a surging romp at very low rpm/speed, like going 3-5 mph through a parking lot. Not knowing any better, I mentioned it at service and they flashed it for me. Big mistake. I have been chasing Ford for a fix. They promised what I expect is this flash back in first quarter 04. But yes, the acceleration is much better. Everything is fine except pilot injection is still gone. I don't suppose I will ever see or hear it again with this truck. Everything else reminds me of the truck I bought. We'll see about the mileage. I haven't put but about 50 miles or less since it was flashed with the latest which is 3U7A-12A650-FTC for my 03 6.0L PSD with Torqushift non-California truck.
Got mine flashed 9/24/04 and that was supposed to fix the turbo lag I was experiencing. WELL, it did. BUT.... it caused something I have been a bit curious about, when I first start the truck in the morning, 75 degrees or 40 like this morning, it smokes quite a bit (black raw diesel). It NEVER did this until this last flash. Also, the exhaust smell is much more pungent at all temps and engine speeds. I do have better acceleration and smoother running, so is this just more fueling or do I need to take it back and try again? Has there been another program released since the end of Sept.??? Thanks for any advise as always guys, Mat
I have an 04 f-250 PSD and I had my truck reflashed on September 8th. Like everyone said, big mistake. I lost a ton of power, and my fuel economy went from around 17-19 to 12-13. I contacted my dealership service dept. today to see if there was a new program out. He said that a new program was released on Oct. 5th, he said it is suposed to be an improvement. I am getting mine in there on Monday I will let you all know if it is any better.
SBV, it's an 04, build date 12/03 technically. I am south of Ft. Worth about 15 miles, travel to Arlington every day for work.
ZUKE, I am anxiously awaiting your answer as I will be there ASAP if it helps, I also noticed a small mileage drop, but nothing compared to what you have seen. Only about .5 MPG and I thought for a while I was just driving harder, but I have concentrated on Lead Foot Control for the last two weeks and it didn't help.
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
I wonder if it is applicable to a late 02/03 build? I would like to get back to the power level of the stock truck. Then when adding the SCMT on top of that it will probably run extra well.
