New flash
Old Nov 15, 2004 | 01:50 PM
  #61
LasVegas F250's Avatar
LasVegas F250
Originally Posted by SBV45
I am showing 16.25 mpg city with mine that is an 03 extended cab, 4x4, 5-speed, 3.73 diff. on the latest flash. I think it has improved.
Are those lie-o-meter numbers? What were you getting on the old flash?
Old Nov 15, 2004 | 02:03 PM
  #62
SBV45's Avatar
SBV45
I don't have the lie-o-meter. I filled to the same spot in the filler neck and divided miles since last fillup by gallons. I keep a spreadsheet on my handheld pocket pc.
I was getting 13-14.5 city with the old flash. Closer to 14 in the winter months. I use Stanadyne or PS with both flashes. 17.5- 18 highway.
I am talking my truck is stock. I know a guy who has a truck same as mine that got 15 city and 19 with a Predator 65HP tune.
Old Nov 15, 2004 | 02:13 PM
  #63
Dr_Pain's Avatar
Dr_Pain
I have a '04/'04 and got reflashed 3 weeks ago and am also seeing a 2 mpg fuel improvement (+/-), not to mention the quiter/steadier start and running idle and better throttle response. I do not have a tuner yet, but the EGR disconnected (that last one is two thumbs up).
Claude
Old Nov 15, 2004 | 02:18 PM
  #64
SBV45's Avatar
SBV45
I can't say mine is any quieter. It is certainly not louder. Much better accelerator pedal response. Shifting is fine. I have not had complaint with the Torqushift.
I give them an A on this one. Even if it was 6 months late.
Old Nov 15, 2004 | 02:51 PM
  #65
$trokin60's Avatar
$trokin60
SBV45 is that spread sheet for your palm pilot and if so how do I get a copy I have all my milage readings and reciepts since the truck was new.
Old Nov 15, 2004 | 03:08 PM
  #66
SBV45's Avatar
SBV45
It is a Microsoft Excel spreadsheet. You just plug in the date, current odometer and gallons pumped and it does the rest. I'll see if I can post it out on the web so you can download it. Maybe I can get Tim to put it in the tech folder.
Old Nov 15, 2004 | 03:21 PM
  #67
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Place it here and it is done
Old Nov 15, 2004 | 03:39 PM
  #68
SBV45's Avatar
SBV45
I just emailed it to you, Tim.
Old Nov 15, 2004 | 06:17 PM
  #69
greendiesel's Avatar
greendiesel
The new flash sounds great. No code with EGR unpluged? Has anyone used the trans-brake with new flash? Mine works great and would hate to loose it.
Old Nov 15, 2004 | 06:22 PM
  #70
IB Tim's Avatar
IB Tim
I did not loose it with the Dec flash....you will be OK
Old Nov 15, 2004 | 06:37 PM
  #71
JZue1's Avatar
JZue1
Hey all, I hear ya's talking about your latest flashes...how do I know what flash I have...mine is a 03/04 build and I've only had it for two weeks. Still learning, and this is the best place to learn. Thanks, Jeff
Old Nov 15, 2004 | 06:43 PM
  #72
AGE mechanic's Avatar
AGE mechanic
If its not under the hood, you will have to take it in to the dealership. If you bought it from the dealer they should be able to give you an OASIS report.
Old Nov 15, 2004 | 06:50 PM
  #73
JZue1's Avatar
JZue1
Well there is nothing under the hood. I got it from a dealership, she is used and has 13,000 miles on it. What is a OASIS report? Thanks, Jeff
Old Nov 15, 2004 | 07:03 PM
  #74
Customz's Avatar
Customz
I spoke w/ my dealer and he told me to stick w/ the original factory flash unless I am having drivablility issues. He also mentioned that turbo lag would be corrected but w/ so many complaints concerning the updated flashes MPG (not this one in particular) he told me to stay away for now.
Old Nov 15, 2004 | 07:07 PM
  #75
JZue1's Avatar
JZue1
I havent had any problems yet, put alittle over 500 miles on her and this being my first PSD, I think it runs great, just thought I'd get better than 13 MPG. Guess I'll just wait till I notice any problems.
