Superchips 6.0 Microtuner Thread
Old May 4, 2004 | 04:43 PM
  #106
FB250's Avatar
FB250
Just purchased a Superduty with 6.0 Powerstroke - less than 500 miles on unit
Would you suggest a break in period before tuning with Superchip?
Old May 4, 2004 | 04:50 PM
  #107
Daryl Hunter's Avatar
Daryl Hunter
Originally Posted by Vic_Ferrari
Yes it does remove the top speed limiter and no it does not show live data.
Is it possible to not remove the top speed limiter?
I never drive my truck that fast and I wonder what the impact would be if I were by some chance involved in an accident and the various parties found that I had "modified the truck to remove the top speed limiter".
I would want the increased power for towing and general driveability but would really drive any faster than I do now. That said, general traffic flow of 85 to 90 MPH on CA freeways is not unheard of.
Daryl
Old May 4, 2004 | 05:18 PM
  #108
Ford1TonsRock's Avatar
Ford1TonsRock
Daryl
It's against the law to go above the posted speed limit, even in Cali
So if you got into a wreck while doing 'traffic flow speeds', you'd still be at fault...
Old May 4, 2004 | 06:57 PM
  #109
4x250cx's Avatar
4x250cx
Vic Thanks for all the great info,I want one!!!! Ive got 0/4 with 0/3 motor 11/03 flash, the #s on my module dont jive with the ones im seeing here,also in your product discription what does; 2003 PS are not warranted to work with 1704,is that the flash ? Do you have any idea with this H/P & Torque increase what the drive line can take,tranny, rear end,transfer case,ect.? Thanks C-Ya at the drags
Old May 4, 2004 | 07:41 PM
  #110
softwizard's Avatar
softwizard
4x,
I also have an 04 with 03 engine built on Aug 29th. If you got the October flash, ignore the number on the side of the PCM. My dealer didn't even put a flash sticker on anywhere when he upgraded me to the October flash.
I had more power and 3 mpg better fuel mileage with the Aug flash that came with the truck so you can bet I'll be ordering a Superchips if the reviews are good!
Old May 4, 2004 | 08:57 PM
  #111
Vic_Ferrari's Avatar
Vic_Ferrari
500 miles is sufficient break-in before installing the tune.
Old May 4, 2004 | 09:01 PM
  #112
Vic_Ferrari
Daryl
I raise the top speed limiter as far as it will go.
(You will never hit it)
I was going 130 in a stock powerstroke with tuning (and some room to go)
Another has been to the 140 mark.
I will NOT specify whether this was on the track or street....just make sure your tires have the correct speed rating and you do this on a test track if you intend to go that fast
Old May 4, 2004 | 09:08 PM
  #113
Vic_Ferrari
The drive train is TOUGH....especially the tranny.
It's a hub/clutch setup with no bands and they are STRONG.
All the 7.3 guys should be jealous of this tranny =o)
I haven't broken one yet, and I've had them over 700 ft lbs at the tire and not being particularly gentle with them.
As with anything else....use your head.
Don't powerbrake it at every stoplight...... =o)
Old May 4, 2004 | 09:33 PM
  #114
Choctaw Bob's Avatar
Choctaw Bob
The only time I powerbraked mine at the drag strip, I smoked the tires ALL the way down the strip(1/8 mile). Had a poor time. I still haven't found a way to get the 2 WD truck off the line.
Old May 4, 2004 | 11:01 PM
  #115
Vic_Ferrari
Powerbraking is not goot for ET's.....it's just for showing off.
This is one issue with stock vs modified....it won't light em up much stock if you just mat it, but after the tune it takes some tactic to get a consistent 60' because you get too much wheelspin.
It'll take some practice but you'll get used to it.
Often times even if you ease into it and mat it when you have traction, you lose it again when you build full boost.
Old May 4, 2004 | 11:25 PM
  #116
Daryl Hunter
That is more or less true, and totally not my point. I didn't say that I drove at those flow of traffic speeds, and speed is not always the sole determinant of fault.
But were one to be involved in an accident while driving at normal legal speeds, and the liars for the opposing party found out that the vehicle had been modified, and that the speed limiter had been removed, I would think that they would use this to stir the pot to maximum extent possible against you. In a civil case, who knows what a jury would think about all that.
Old May 4, 2004 | 11:37 PM
  #117
Daryl Hunter
I spotted the goof in my original post that is confusing folks.
I meant to say that I don't drive that fast now and would NOT drive faster with the tuner mods installed. I would rather not have the speed limiter disabled or moved to a higher limit.
It is highly unlikely that I would ever exceed 90 MPH in the truck under any circumstances. I want the extra power to tow my trailer and for general driveability.
I used to roadrace motorcycles as a hobby and still do track days regularly - hence the toyhauler trailer. If I have a need for speed I take my bike to the track and do 160 MPH there. Nothing like dragging your knee around a turn at 140+ MPH!
After that, putting around in a big clanker of a truck no matter how pumped up by a tuner seems rather anti-climatic ;-)
See my web site at http://www.trackcam.com for on track video - including a practice crash or two . . .
Old May 5, 2004 | 07:18 AM
  #118
Vic_Ferrari
When you install our tuning, the top speed limiter is raised. If you would like to leave your top speed limiter stock, then leave the truck stock!
No one is going to know it's raised but you.
Old May 5, 2004 | 08:10 AM
  #119
blown5.4's Avatar
blown5.4
well it sure wasn't on the track i can tell you that
Old May 5, 2004 | 08:12 AM
  #120
Vic_Ferrari
How do you know it wasn't a test track?
Not ALL tracks are 1/4 mile, you know =o)
