Injector Service???
Old Feb 4, 2004 | 08:33 PM
lariatbob's Avatar
lariatbob
Injector Service???
Hi Guys (and Gals)
Just had my truck in the dealer for the CPS. He suggested I make an appointment to get my injectors "flushed" by some special machine. Cleans and lubes them, he says, and they recommend it every 30k.
Anyone had this done? Is it needed, does it make a difference, would you recommend it?
2000 PSD 40k
Thanks as usual,
Bob
Old Feb 5, 2004 | 08:19 AM
JMorton's Avatar
JMorton
We offer the BG Fuel Injection Service for both gas and Diesel engines. I did my 97 Shortly after purchasing it and really didn't notice much difference in the way it ran. I've had customers tell me they noticed a seat of the pants difference in driveability though. I have noticed a difference in power on my gas engines after doing the flush. I think it's a good service but is a little pricey.
Old Feb 5, 2004 | 08:42 AM
rmilchman's Avatar
rmilchman
Would the service do anymore then putting straight Standadyne on the fuel filter bowl when changing the filter?
Old Feb 5, 2004 | 08:44 AM
JMorton's Avatar
JMorton
Probably, the machine we use is hooked into both fuel pressure and return lines and runs a ton of solution through. We run it a minimum of 30 minutes then replace the fuel filter because they sometimes plug up after the service.
Old Feb 5, 2004 | 10:34 AM
bilder12's Avatar
bilder12
If mine isnt broke --- I dont fix it. I have 78k on the clock of my 2000 and no problems with injectors. I just run some stanadyne thru it once in a while. or Howes fuel treatment. (hehehe, this ought to open a can of worms)
Old Feb 5, 2004 | 08:22 PM
Rick_from_Mass's Avatar
Rick_from_Mass
After Market Injectors
My PSD had been running rough the last week and brought it in to get it checkout for codes... Bad injector, itcost me $723 to replace the injector and $114 to check it out....Ouch!!!
The injector was $327 the rest labor....
I need direction in buying a good manual and also do they make aftermarket injectors?
99 E450 cube van
Rick
Old Feb 5, 2004 | 09:36 PM
horsecop's Avatar
horsecop
Rick, try eight of'em!
Old Feb 5, 2004 | 10:03 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Rick
You can get brand new Alliant Power stock injectors for less than what the dealer charged you for a rebuilt.
You can also get a good shop manual c/d off of e-bay for $30-40.
Old Feb 8, 2004 | 07:52 AM
Idaho Dan's Avatar
Idaho Dan
Re: After Market Injectors
99 E450 cube van
Rick
I had the same problem awhile back (number 8 was bad). I took it to Ford and the wanted $650, so I paid them the $80 diagnose and took it to a local deisel shop and they did it for ~$450. Didn't save much overall, but felt good about not donating anything extra to the dealer.
HILLBILLY BOB
Sep 26, 2012 07:16 PM
bobs1948f1
Dec 5, 2009 11:36 AM
bob150
Dec 6, 2006 05:02 PM
Bobber72
1997 - 2003 F150
Sep 1, 2003 10:32 AM
Biscuit
Electrical Systems/Wiring
46
Mar 1, 2003 05:27 PM
