Sponsored by: Auxito
F-150 auto shifter
Old Aug 31, 2003 | 10:48 PM
Bobber72's Avatar
Bobber72
F-150 auto shifter
Hi folks, an inquiry for my son. He's got a '97 F-150 with 4.6 l and automatic trans with the column shifter. He called this evening to see if I had any ideas, you guys are my recommendation.
When he starts the truck, he is not able to take the shifter out of Park. If instead, he places the key to auxilliary, he can then start the truck in neutral, and is then able to select any gear he wants.
Has anyone else encountered this problem, and if so, what is the solution?
Thanks for any and all help!
Bob
Old Sep 1, 2003 | 08:17 AM
jonmech's Avatar
jonmech
F-150 auto shifter
check to see if he has brake lights, the lock actu. for the shifter is run off the brake switch.
Old Sep 1, 2003 | 09:25 AM
Bobber72's Avatar
Bobber72
F-150 auto shifter
Jonmech, you hit the problem exactly! Thank you. Obviously, his next question is where is this switch LOL. I would assume it's not like the old days where the switch was on the master cylinder, but I'm 70 miles away, and haven't looked for it.
Thanks again, jon!
Bob
Old Sep 1, 2003 | 10:32 AM
Racerguy's Avatar
Racerguy
F-150 auto shifter
The switch is on the brake pedal lever. It has 2 green wires going to it. Check all the fuses first.
turnrjr
Feb 25, 2017 02:30 PM
rat49f6
21
Aug 18, 2009 03:55 PM
f100guy
Mar 1, 2005 08:19 PM
rocketman77
Jan 27, 2005 06:35 PM
