Oh yeah... I'm sure ocean water does things to bearings like the salt/spray does to vehicles here if not maintained...
Have a safe trip.
I fish inshore saltwater in Texas at least once a week. We luck out and don’t have to deal with vehicle rust, but my goodness boats and trailers take a beating. Here is my top of the line 5 yr / 100k mile warranty vault hubs and axles after 2 years and a couple thousand miles. Rinsed religiously….
To avoid completely derailing the thread: My 2016 does this every once in awhile with DEF warnings. I refill the tank and the warning will reset itself after a couple of drive cycles.
Just an update. Although the “chicklet” symbol for the DEF issue went off yesterday the CEL was still on display until this morning when I started it. The display - I am happy to say (hesitantly) is back to normal.
For a 2021 Ford F-350 with the 6.7L Power Stroke, the factory emissions warranty is generally 5 years or 100,000 miles for diesel emissions components under Ford’s warranty guide and diesel warranty information. Ford also provides a diesel engine coverage period of 5 years or 100,000 miles for the engine and certain related components.[ford +1]
What is usually covered
The emissions warranty is meant to cover defects in emissions-control parts, not normal wear items or damage from misuse. For diesel F-350s, this typically includes major emissions hardware such as aftertreatment-related parts, depending on the exact configuration and certification.[ford]
Important exception
Some specific emissions components can have different coverage due to recalls or special warranty extensions. For example, Ford issued an extended warranty for certain diesel particulate filter issues on some 2021 vehicles, increasing DPF coverage to 10 years/185,000 miles or 10 years/110,000 miles depending on application.[nhtsa]
I had this happen to me about a month ago. Made an appointment with the dealer for two weeks out! (The soonest they could get me in).
Then I figured I couldn’t be the only one and went online and found this video.
Although he uses his diagnostic tool to verify the temps basically you fill up the tank then run it in neutral at about 2300 rpm for about 25 minutes ( I’m not sure of the time) then drive it down the road and the warning will disappear. In my case it was probably caused by putting in def when I was below 1/2 full but not necessarily filling the tank which didn’t allow the sensor to reset.
Started truck this morning here in St. Petersburg and the def warning ⚠️ came on again. I checked def gauge and it indicates 5500 miles to E. I decided to go to a local Ford dealer and on the way over the ‘chicklet’ symbol and warning turned off.
Frustrating to say the least.
In that other post I linked above there is a TSB that they performed on my truck, not just that emissions recal/reprogram. I do have the same year truck as you so I figured that could be it? I think my CEL went on and off aas well as the message appeard and disappeard but the code was still in the computer..
Understood. Hopefully I can get back up north without issue and get over to Ford dealer and ask about the TSB.
Put ~600 miles on the truck after leaving St Petersburg today. Truck played chicken with me giving me a warning that a derate upon restart would only allow me to travel 50 mph. When I restarted it all the warnings were gone and only CEL as left in display.
Interestingly my DEF Gauge reads full with the analog needle but the digital display says ‘65000’ miles until empty.
