snake oils?
Old Apr 18, 2026 | 07:50 AM
Split rims's Avatar
Split rims
snake oils?
Old Apr 18, 2026 | 09:51 AM
Painted Horse's Avatar
Painted Horse
Utah doesn't mandate any Cetane or Wear scar standards. So refineries can get away with using the Federal minimum.
So I don't see any stations in Utah advertising a Premium Diesel. So unlike Texas as mentioned in the video and I believe California also has a premium. There is no premium diesel in Utah.
There are four refineries in Utah, And last I heard, about 70% of their production is shipped out of the state. Fuel is trucked to neighboring states and there is a major pipe into the Northwest.
All the crude oil refined at the local refineries comes from Utah. There is a large oil field in the Uintah basin. That crude has a high parafin wax content and I know they take special procedures to refine it.
In the absence of state standards, about all I can do is inspect my fuel filters and see if they are getting dirty between fuel changes and add a lubricating product just in case.
Old Apr 18, 2026 | 10:40 AM
SARDiverDan's Avatar
SARDiverDan
California minimum cetane rating is 53 but I still use opti-lube xpd on every fill.
Old Apr 19, 2026 | 10:14 AM
Overkill2's Avatar
Overkill2
New York has a 40 cetane minimum, so I'll keep using my additives for added cetane level.
Old Apr 19, 2026 | 03:33 PM
SDER1's Avatar
SDER1
Will continue Opti-lube products, shifting to boost and summer formula next fill-up in a couple days and 3x $$$ more in a 48 gal tank. Mid-Atlantic coastal region.
Old Apr 19, 2026 | 09:48 PM
pkarhoff's Avatar
pkarhoff
Trojan Pig
Same here in AZ, the diesel is ****e! I'll keep using OptiLube XPD or ArchOil 6500. His whole reasoning for saying to not use them is the possibility of debris. That is a fart in a stiff wind at best.
Old Apr 19, 2026 | 10:23 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I wonder if that is the cetane rating for the B20 in CA. From all I read, the R99 sold in CA has a cetane rating of 70 or higher.
Old Apr 21, 2026 | 11:59 AM
SARDiverDan
53 is for standard diesel. While R99 has a minimum rating of 70, there are a number of articles out there that argue that the ideal cetane rating for a modern diesel engine is somewhere between 45-55 so it all comes down to what study you want to support. My local truck stop sells R99 and I put in Opti-lube which bumps it up another 3 points or so and that would put it way above what might be ideal. I started a thread back when this fuel first showed up around here and so far, I have not noticed anything different in how the truck starts and runs.
Old Apr 21, 2026 | 01:56 PM
chadstickpoindexter
Yeah, that is why I stopped using Hot Shots when using R99 and went to OptiLube XL. Hot Shots boosts the cetane levels, whereas the XL doesn't. But the XL has super lubrication properties! I personally haven't noticed that the truck runs any different on R99, or start ay different either... however, the coldest temps we saw this winter was 34F! lol.
John in OkieLand
Jul 21, 2025 05:33 PM
Tsubakihara
Dec 20, 2023 05:09 PM
TheFist
Jun 10, 2008 12:35 PM
numocystic_10
Oil & Lubrication
Sep 13, 2002 05:26 AM
