Sponsored by: Real Truck
Error Codes 7E8 and 7E9 A/T
Old Aug 6, 2024 | 11:02 AM
craig6racing's Avatar
craig6racing
2nd Gear
I have a 2012 F550 SD Powerstroke 6.7L, automatic, with about 75000 miles. It threw a code for a problem in the DEF system, so we replaced the complete DEF tank assembly with a supposed good used assembly. Test drove the truck for 20 miles and that code did not return. I then replaced one battery that was bad. Check engine light came back and now I get error codes 7E8 and 7E9 A/T. Any thoughts to a simple fix?
Old Aug 6, 2024 | 02:53 PM
ifrythings's Avatar
ifrythings
Not sure what scanner you’re using but those aren’t codes, they are module ID’s 7E8 is the PCM, 7E9 I believe is the TCM. Could these be menu items in your scanner that could have codes in them?
Old Aug 6, 2024 | 03:44 PM
craig6racing
2nd Gear
Yes, I called them codes for lack of a better term. I want to know if and how I can get rid of them. I have a cheapy scanner, so I may have to find a good one and try to erase them.
Old Aug 6, 2024 | 06:38 PM
projectSHO89's Avatar
projectSHO89
You need a better scan tool to READ the codes first. Record them. Do not simply erase them.
gtex
Aug 19, 2018 07:40 AM
keninwa
2009 - 2014 F150
Jun 30, 2016 12:32 PM
djbeck88
17
Feb 2, 2011 05:00 PM
fastball
Nov 7, 2008 11:20 PM
