Sponsored by: Auxito
Checking codes
Old Oct 12, 2007 | 07:24 PM
lucky13's Avatar
lucky13
Checking codes
Ok my father in law has a 2002 F150 w/ 4.6 and 90K miles on it. His "Service Engine Soon" light came on. Is there anyway that I can check the codes without using a scanner? I tried searching but didn't find anything about it. I live in Northern Ca, and they are in Southern CA, so none of my tools or scanner are here. Thanx in advance.
Brian
Old Oct 12, 2007 | 07:35 PM
wtesh's Avatar
wtesh
Codes check
Whats wrong with taking it to Autozone
Old Oct 12, 2007 | 08:36 PM
lucky13's Avatar
lucky13
id rather do it myself. The closest autozone to my inlaws is almost 40 min away. On my Dakota I can check the codes without needing a scanner. Just thought that maybe the Ford would do it also.
Old Oct 12, 2007 | 09:24 PM
Bluegrass 7's Avatar
Bluegrass 7
If you invest in a about a $50 code reader for OBDII, it may be a better way go.
Actron has a low end unit that will do this. Just a reader and code clear function.
You need a code chart to see what the code is referring to for the system in fault.
Old Oct 13, 2007 | 07:57 AM
projectSHO89's Avatar
projectSHO89
Last I heard, AutoZone stores in California weren't doing scanning. Don't know if that has changed.
A basic code reader costs about $60 at WalMart.
Steve
Old Oct 15, 2007 | 09:54 AM
KingRanchMan02's Avatar
KingRanchMan02
Ford does not have the feature that Dodge does. You will need to get your own scanner from back home or do as others have suggested here. Good luck!
