How bad is the HG job on a 7.3 IDI?
Old Mar 4, 2026 | 01:15 PM
  #136
steelholder's Avatar
steelholder
The front and rear seals state to install dry yet some in suggests to put a thin layer of RTV. What do you guys think?
Old Mar 4, 2026 | 01:43 PM
  #137
FORDF250HDXLT's Avatar
FORDF250HDXLT
I put some ATF on just to help and and tap it in. I've never used RTV on any press fit seal like this on anything. I didn't even know some people do. I doubt that's advised in any manual worth a lick. I could be wrong, it's just I've never of it. I guess it probably couldn't hurt anything....but I highly doubt it does anything either.......Well put it this way, if it were needed, the seal wouldn't be made properly, so.
Old Mar 4, 2026 | 08:46 PM
  #138
steelholder
I installed this backwards didn't I?
Old Mar 4, 2026 | 10:11 PM
  #139
FORDF250HDXLT
I replaced mine right after knocking it out, so I just copied it, not thinking much about it. It's been too many months to recall exactly now though. Hopefully someone else chimes in to confirm. Don't see any photos anywhere or youtube vids? Really seemed like it goes in from the outside, not the inside like that, but I sure don't remember. I was so many hours changing stuff over from engines it's all a blur. I was right in the middle of a very large tree job and I was hustling to get that truck back on the road.
Oh. What about my photos in my log truck thread? Let me see what I have.
Shoot, looks like I didn't stop and grab a pic of the rear main install.
https://www.ford-trucks.com/forums/1...l#post21568639
Doesn't that original seal there look like it's installed from the outside though? Opposite from yours?
Old Mar 4, 2026 | 10:49 PM
  #140
steelholder
A couple things regarding this rear seal..
1) I noticed, as soon as I got mine, that the rubber lip seemed wrinkled or "wavy". I asked CDD about that and they said it was normal but I am still doubtful (see pic 1).
2) I have sourced 2 different pictures that appear to show the seal going in, in both directions, one pic is the way I did it the other way has the lips facing towards engine not towards trans. My way is lips facing towards trans(see post 138 to see how mine is). Pic 2 is facing towards engine (Nick PIsca).
Anyway I have decided to get a new rear main seal just for peace of mind and I'm going with the National 3893V everyone seems to like. Im almost positive I had a leak there and I know this is the PITA to access without removing the enjoy so why not? Just kinda frustrated with the way it's supposed to go in??
Old Mar 5, 2026 | 12:21 AM
  #141
ihc1470's Avatar
ihc1470
It has been many years ago the last time I replace a rear seal on a 6.9. The direction when installed correctly the lip points towards the oil source, in this case the crankshaft. You normally press a seal in from the side that is closed or in this case the side that has the words on it. If it is going into a hole that does not have a bottom to it then you could press the seal in backwards. As long as the lip is point to the oil source it will be correct. Some seals have a secondary lip that faces the opposite direction so those can be a little more interesting. The main seal lip should be the larger one and normally also has a spring around the inside of it. Again that goes to the oil side. Hope that helps and makes some sense. If you have ever repacked wheel bearings think of those seals. They can only be driven in one direction and the lip of the seal points towards the grease and bearings.
Old Mar 5, 2026 | 12:54 AM
  #142
steelholder
That makes sense, thanks. What's a little surprising to me is doing research in this and seeing so many pictures and posts of people installing it the opposite way and no one really catching it unless you look at it closely. These same people don't seem to report back with issues of leaks in this area.
Old Mar 6, 2026 | 05:48 PM
  #143
FORDF250HDXLT
How's things going? Back on my main pc again, I have access to my records. For the replacement engine in my F450:
Felpro Rear Main seal Kit BS 15868-1 - rubber (advance auto locally had it in stock. Had I thought of it, I would have
ordered and used the higher end Fluoroelastomer seal instead though, like Precision Multi-Purpose Grease/Oil Seal - 3893V or MAHLE Rear Main Seal - 68028)
Although my notes show I researched options too late, I bet the rear main doesn't leak for decades. I'll eventually need to have a fresh reman trans put in this truck, and I doubt I'll bother updating the rear main seal at such time, that's how little I'm concerned.
MAHLE GS33679 Engine Oil Cooler Mounting Kit
Old Mar 6, 2026 | 05:59 PM
  #144
steelholder
I ordered a new rear seal. Went with the national. Waiting for that to show up. I installed Speedy sleeves on the rear crank and will be installing one on the harmonic balancer for the front seal, waiting for that one to show up. I removed the front plate cover to have better access when pressing that seal in. Now that I have the water pump out and the main front plate out, I will be doing all those gaskets as well. I ended up getting my heads resurfaced, glad I did. Everything is in a in between/ almost there stage.
Old Mar 6, 2026 | 06:38 PM
  #145
FORDF250HDXLT
Good job, bud! Looking great. Keep at it. I believe success is in your near future.
Old Mar 6, 2026 | 07:52 PM
  #146
Leroy Unlisted's Avatar
Leroy Unlisted
Looks Purty
Old Mar 6, 2026 | 10:19 PM
  #147
steelholder
No one could've prepared be for how much a PITA it is to remove all this old fossilized gasket. I'm using that CRC gasket remover with a razor blade and the wire brush on the grinder so it helps but wow.
The front plate seems to have a good amount of pitting on the surface where the water pump bolts on to. Is this normal? Did a quick ebay search to see what they may cost - lots of rear plates but not a single front plate, not just on ebay but anywhere...scary
Old Mar 7, 2026 | 08:06 AM
  #148
FORDF250HDXLT
That's nothing a light coat of Permatex Water Pump & Thermostat RTV can't handle.
Old Mar 7, 2026 | 05:09 PM
  #149
steelholder
Could you guys help me locate exactly where these go? The bottom right gasket with blue seems to go on the oil cooler but mine isnt shaped like that or I cant find that spot. Did they make more than one type? Which of these is the oil pick up tube gasket and where is that located? I know one or couple of these is related to the thermostat ( which I didnt replace for now). Is the top left the diptstick o-ring? Not sure where on the tube that goes, how about the bottom left? Thanks all.
Old Mar 7, 2026 | 09:30 PM
  #150
BigBlue2's Avatar
BigBlue2
They put in two gasket types for the cooler. The three bolt one is for Vans only.
