Crank No Start
Old Feb 12, 2026 | 06:46 PM
  #106
90project5.0's Avatar
90project5.0
One day you’ll be able to do the same for someone else posting! That’s all the payment needed!
Old Feb 20, 2026 | 04:44 PM
  #107
DJ17490's Avatar
DJ17490
Well. Never was able to get around to that test yet cause life decided to get in the way. However this morning it decided it wants to have a misfire now so thats always good fun. Decided to try and use the new code reader to figure which one, I know its drivers side due to true dual exhaust, but it refused to do the cylinder balance test, possibly due to no spout or some other stupid reason. I pulled cylinder 8s plug figuring it was that but it wasn't, I'll have to check the other 3 later. The joys
Old Feb 21, 2026 | 01:48 PM
  #108
DJ17490's Avatar
DJ17490
Well. As I've learned I'm missing on 2 cylinders not 1. Number 6 and Number 7. Ran a compression check 7 is at 130 so its not that. 6 is at 105 so that may be a problem. They seem to still have spark at least
Old Feb 21, 2026 | 05:04 PM
  #109
DJ17490's Avatar
DJ17490
Got the valve cover off. Drivers side so egr got in the way and made everything awful. Valve train moves as it should so its not that I think. Leaves me with a possible head gasket or a bad ring. Based on my coolant never staying in the reservoir but also not leaking or going through it fast at all I'm leaning at the gasket, just wherever its bad its not mixing with the oil
Old Mar 2, 2026 | 12:59 PM
  #110
DJ17490's Avatar
DJ17490
Well. Another update on this mess. Ran some tests. Can confirm that its not the gasket I think, didnt take the heads off to really check, however I did have napa test the injectors and I have 5 leaking and 2 broken ones so that may explain many things... I guess in that case anyone got a good recommendation for replacements? I may as well get good quality ones while I am replacing them
Old Mar 2, 2026 | 01:47 PM
  #111
AuroraGirl's Avatar
AuroraGirl
YOUR NAPA has a injector tester?
Old Mar 2, 2026 | 01:48 PM
  #112
DJ17490's Avatar
DJ17490
That they do. To be fair this is a college town with a big automotive school. They were able to flow test them and give me that info
Old Mar 2, 2026 | 03:49 PM
  #113
DJ17490's Avatar
DJ17490
I guess in this case is should I see if I can even find the stock single port style or get a set of the 4 port ones from the later years. Probably just get the oem bosch ones but idk if the later ones are actually an improvement or not. I've seen with the xj jeeps doing a similar upgrade can cause some issues. Didn't know if itd be the same here
Old Mar 2, 2026 | 07:44 PM
  #114
90project5.0
https://lmr.com/item/LRS-9593-19K/mu...SABEgKoOvD_BwE
Old Mar 2, 2026 | 08:13 PM
  #115
DJ17490's Avatar
DJ17490
I believe the 460s require 24lb injectors compared to the small blocks 19. I'm debating getting oem bosch ones for about 35 a piece or skp from rockauto for 25 a piece. With the system being batch fire over sequential I kinda feel like the extra ports wouldnt provide as much benefit as one might think. Atomizes better sure but when it has to sit there for a sec because of the batch system it doesn't really turn out any better from what I've read. That and the multi ports seems to get clogged easier.
Old Mar 2, 2026 | 08:48 PM
  #116
90project5.0
https://lmr.com/item/LRS-37263/musta...iABEgKHIfD_BwE
Old Mar 2, 2026 | 08:50 PM
  #117
DJ17490's Avatar
DJ17490
Now those are tempting. I'll do some more looking tonight and have em ordered tomorrow. After that point I'll update again once installed
Old Mar 9, 2026 | 03:24 PM
  #118
DJ17490's Avatar
DJ17490
Well. Got the new injectors put in. A set of oem Motorcraft/Bosch ones even. Didn't fix whatevers wrong with it. It idles fine up front it seems like, doesn't sound like its running rough and maybe a little bit of injector clatter for noise but no crazy ticks or anything. But drivers side exhaust just sounds like its missing. It does seem to idle smoother from the other side and throttle response is much better at least. I don't even know at this point. Thinking could be carbon build up in the exhaust since the egr ain't working right but who knows. Just something else to look at before pulling heads maybe.
Old Mar 9, 2026 | 04:29 PM
  #119
90project5.0
Do you have headers? You could try to pull off the header on that side and pull the spark plugs. Then shine a flashlight in the exhaust ports and see if you can see any light in the cylinder. Do it at night (easier to see light or use cheap bore scope) and each cylinder needs valves closed either by loosening the rockers or rotating engine.
Old Mar 9, 2026 | 04:41 PM
  #120
DJ17490's Avatar
DJ17490
No theyre manifolds. I have headers for it just havent put em on yet. I may end up pulling them at some point anyway to check them but it may be a while. Motor for my Cobra just got done at the machine shop so my money focus is probably gonna go to finishing that project over fighting this anymore for the time being.
